Schiit SYS Passive Preamp
Apr 18, 2014 at 8:25 PM Post #32 of 231
its a pre amp you still need a headphone amp ex im planing on a stack with sys and vali
  Will it sound better than the Vali with my HE-400's?
its a pre amp you still need a headphone amp ex: im planing on a stack with sys and vali. so it would make the vali perform better thus making the headphones perform better
Apr 19, 2014 at 10:18 PM Post #33 of 231
Will it drive my earbuds as well or is it too powerful?  Should I look for a weaker amp like a fiio for them?
Apr 20, 2014 at 1:40 AM Post #34 of 231
schiit sys in a nut shell Sys is a simple, 2-input passive preamp. No electronics. No power. No distortion. Just a 2-way switch and a potentiometer.
 what is a potentiometer you say this can tell ya  http://www.wisegeek.com/what-is-a-potentiometer.htm http://schiit.com/public/upload/general/imagecache_thumbnail_product_gallery_large/sys_board.jpg basicly the sys preamp prepares the signal to be amped properly
Apr 20, 2014 at 8:30 AM Post #35 of 231
as this is analog preamp it does not alter the single at all, it gives you an vol control........that's all.........it does not even has an headphone out or speaker out. If you do not need an 2-way switch then emotiva control freak is also an good option, I am using it between PWD 2 and UPA 200 power amp which does not have an Vol control.
http://shop.emotiva.com/collections/accessories/products/control-freak
Apr 20, 2014 at 3:16 PM Post #36 of 231
Is it confirmed that the SYS doesn't work in both directions?  Or has nobody actually tested it yet?  I'm another that would like to use it backwards (one in, two out).
Apr 20, 2014 at 7:58 PM Post #37 of 231
This is what I have in mind. Though, please correct me if this is what the Schiit SYS is supposed to do.
        ----------->Lyr------>Heaphones
MBP----->Bifrost----->SYS (What I want it to be able to do)-
        ------------> External Computer Speakers
Apr 20, 2014 at 10:18 PM Post #38 of 231
Yes, that setup makes sense as long as you're using powered monitors.
Apr 21, 2014 at 12:09 AM Post #40 of 231
The SYS is designed with two INPUTS and one OUTPUT.  Until someone confirms that it can be used backwards, I wouldn't expect that the setup above will work.  FYI, this is basically what I want to do with it.  Waiting to hear if it's possible.  Maybe I'll email the Schiit guys about their return policy...
Apr 22, 2014 at 12:29 PM Post #42 of 231
I'll try and test it backwards this coming week
I went ahead and ordered one, while I was ordering the new Modi optical.  I'll see for myself and post results here as well.
Apr 22, 2014 at 1:34 PM Post #44 of 231
