superultramega
Thanks for the thoughtful reply. Yes that's the tube amp.Hi,
I'd let Ragnarok play for a few days, whether you are in the room or not, hps or speakers should be fine..
I have found that I have to adjust my speakers to the room/amplifier/dac. Example if I'm using ragnarok 2 as an amp for say my Zu Omen DW2 s, I wont have the same exact speaker placement when I try a single vidar, or dual gjallarhorns. Playing with speaker placement will likely change your separation/imaging.
Also, good tubes amps are, well, really good..
I never feel like the lead singer is far away from the band, just a step or two in front..
What headphones are you using. Balanced or Single Ended?
I found the built in USB dac to be good enough if I needed it, but I preferred any of my separate dacs with Ragnarok 2 over the USB card..
I think the phono card in ragnarok is better then my Mani 1 preamp.
I find Ragnarok to be more polite and refined then my tube HP amp or the MJ3. Very detailed, but definetly not as tube like..
Edit - Is this the tube amp you are using? It has a choke! Looks to be a really quality item..I'm not suprised the presentation is different between Rag 2 and the tube amp, even without price consideration... 2 Tyrs might be a fairer comparison..
https://iconaudio.com/stereo-40-mkiv-integrated-kt88-amplifier-stereo-40-mkiv
I was hoping to get a SS integrated for a secondary system, not equaling cost or sound performance of my tube amp but more convenient for others to use while also giving a different sonic signature. If the Ragnarok is representative of SS amps around this price, I might be a tube guy? I'm not ready to have this different of a sound in my secondary system, my ears can't adjust fast enough. But I will use my 15 day period to see if the sound changes (or if my ears adapt).
Using Hifiman Ananda Stealths, single ended. Is there any benefit to balanced other than higher volume? I don't have any balanced input/sources.
Polite and refined is a good description. I would also say crisp and precise. But for me not great with intimate music. Actually I've found over the last few days it sounds best with loud rock and symphonies.
