estreeter
- Jun 10, 2009
Whee - do I get a prize if I'm the first one to post a photo of the Gungnir / Mjolnir combo driving my LCD-3s ?
Any chance the Mjolnir will be available in black? It would help a lot with the wife acceptance factor...
I want to demo one! I'm right around the corner from Schiit too
No, but you could choose to pop the cover and have it anodized black. I'm thinking about doing that very thing with the Bifrost and Lyr. The only reservation is loosing the Schiit logos.
Then why not try some schiit out?
I don't know the proper procedure to try said schiit out.
The procedure is to get your ass down from LA and head to T.H.E SHOW in OC this weekend. They've got all their Schiit down here.
Much better diaphragm control and dampening.
Singled-ended connections use only one wire for the signal for each channel while using a common ground, so any music produced is caused from the signal being offset from the ground so there's a chance of crosstalk between channels (collapsing the staging), whereas balanced has two signal wires for each channel with no interference from the other channel.
Signal degradation based on conductor quality is much less with balanced, so those expensive silver cables people swear by in single-ended systems will make much less of a difference in a balanced.
Well just cover the logo with tape when you spray the top lol
I'm afraid that's incorrect. Generally speaking, "balanced" amps ("bridged" is a better term) have higher output impedances than their single-ended counterpart as the output impedance is twice that of the non-bridged single-ended circuit. Higher output impedance means less diaphragm control.
Both "balanced" and single-ended use two wires. And there's no less crosstalk between two balanced lines than between two single-ended lines.
You'd need to go out of your way to find a conductor whose quality degraded the signal to any meaningful degree, and should there be any signal degradation due to conductor quality, the degradation would be no less in a balanced line than in a single-ended line.
Jason has stated in email that the Mjolnir is the first SS amp that doesn't make him miss tubes. This was some weeks back. I wonder if the final version will retain this quality. The real test is with the HD800. Looking forward to those impressions.
