UntilThen
- Jun 16, 2015
What a sweet rig! Can only imagine how great that sounds!
Thank you. Sounds just like the mothership.
I was considering those tubes in the past but I believe the ma on them is 450 which may be too much for the MJ2. I think 400 is max.Triple mica, tall black plates, D getter 5965's.
What are the chances that these won't completely suck?
Ouch. Yup. Should work ok in Valhalla2, though. I've used 6sn7's in there.I was considering those tubes in the past but I believe the ma on them is 450 which may be too much for the MJ2. I think 400 is max.
The Mjolnir II stock tubes are of the 6922 (or equivalent) type: the ‘mA’ per tube is 300.I was considering those tubes in the past but I believe the ma on them is 450 which may be too much for the MJ2. I think 400 is max.
There's a post on the MJ2 tube rolling thread, #5, that refers to feedback from Nick (@schiit) that 415 mils is the max recommended.The Mjolnir II stock tubes are of the 6922 (or equivalent) type: the ‘mA’ per tube is 300.
…will look like Chevy Chase house in Christmas Vacation?…There's a post on the MJ2 tube rolling thread, #5, that refers to feedback from Nick (@schiit) that 415 mils is the max recommended.
I've considered making adapters that expose the filaments, so that I could power them from my big DC supply...
Let us truly hope not. I have a 30 amp capable variable PS nearby, a fused distribution panel, Powerpoles aplenty...…will look like Chevy Chase house in Christmas Vacation?…
…after all, the gear must earn its keep…you are not running a charity………I'm letting Gumby and MJ2 have a break whilst I spend some time getting to know my Burson Conductor 3 Reference which arrived today.
I'll keep my favourite and let the other go.
What h/p cable have you been using (with the Clear)?I'm just getting to know my MJ2 and Gumby (had about 3 weeks). Got my adapters in earlier in the week, and trying various tubes now. CV455 from Langrex, RFT ECC81 recommended in this thread, Amperex 7308 PQ (white lettering), CV4033 (not in yet), RFT ECC82 (also not in yet), and Tungsram ECC82 black plate no holes, single pole, solid plate getter (recommended by Wes). Those have been tough to find but I was able to get my hands on a few. So far they are the clear winner (and freaking amazing) with the RFT ECC81 in 2nd place (a bit bright for my taste but reveal details like crazy. Will report back with some pics soon.
I use OG Focal Clears but I'm now the proud owner of the ZMF Verite Closed stabilized Atoll. They just shipped out today and I was thrilled to get them.
I have one from a store named Halsey on Etsy that has been pretty good. Way better than the stock cable from Focal. Using the balanced output. Can't wait to put my Forza Noir Hybrid HPC into action when the Verite Closed arrive though.What h/p cable have you been using (with the Clear)?
I disliked the stock Focal cable: looked good, too clothy & stiff, microphonic ! I bet that Forza/VC is a sonic KO.I have one from a store named Halsey on Etsy that has been pretty good. Way better than the stock cable from Focal. Using the balanced output. Can't wait to put my Forza Noir Hybrid HPC into action when the Verite Closed arrive though.
