I think I was sold a faulty second hand unit with a blown fuse, anyone know off hand what fuse is supposed to be in the socket? thanks
Schiit Mjolnir 2 Listening Impressions
monkey5949
Holy hell -> this stack is amazing.
Can change the setup through
1) Tubes
2) Pads
3) Cans
Puter -> Gungnir -> Mjolnir +Socket Savers+ 1965 Amperex BUGLE BOY 6DJ8/ECC88 -> Forza -> Verite Opens
Just so much audio bliss, Building a collection of tubes I may never get to.........
1) Tubes
2) Pads
3) Cans
xtiva
Hi new Mjolnir 2 owner here...
Just wanted to find out if you find below to be true with your Mjolnir?
This is first tube amp but find that in terms of sound stage it has width but not depth? What i mean is that all instrument, are in single line in front of me?
only amp I have to compare right now is SPL Phonitor and find Mjolnir seem to have more width but Phonitor seems to have much more depth, can feel instrument are in different distance from me...
Thanks.
Thanks.
monkey5949
There is a bit to understanding what you are hearing.....what is your source, dac, and cans. It could be the Mjolnir is shallower but I haven't had that experience.Hi new Mjolnir 2 owner here...
Thanks.
xtiva
Thanks for the reply and shallow is what I was trying to say new to head-fi world...
Playing Classical music, encoded in 24bit 192K FLAC file using Raspberry PI running Moode Audio connected via BNC to Holo Audio Spring 2 Level 2 DAC.. and Sennheiser HD800 for headphone...
Smoothstereo
What tubes are you using in the Mjolnir2 ?Hi new Mjolnir 2 owner here...
Thanks.
xtiva
HI using Amperex orange globes tube, which looks to be choice of tube for the Mjolnir......What tubes are you using in the Mjolnir2 ?
monkey5949
Ha no worries....im relatively new here myself.....its just the use of adjectives. Your setup looks to me like a solid chain. I don't have much experience with any of that gear but know a bit of it by reputation.
A final change that may influence the depth of sound ould be had by changing out the tubes.......part of the beauty of the amp...
rolling tubes for different sound. If you plan on experimenting a bit I recommend a set of socket savers...
xtiva
Oh thanks for the info.. got it as second hand,and it came with socket saver and with Amperex tube...
would you recommend a tube for depth?
Thanks once again.
monkey5949
Thanks once again.
I don't really have a specific recommendation for a better soundstage but there are a couple threads in Headfi that go through tubes and the sounds they produce give me a moment I'll see if I can figure find....also I have a collection of 6-7 sets of tubes....with the variables I mentioned above, i like the ability to play with sounds.....so far I've messed around with 3-4 pairs of tubes....I found what I liked and stuck with it....however in the midst of changing out a few of my headphones so may have to start all over.....but to me this is part of the fun. Keep that in mind and take any recommendations on here in that context.
monkey5949
Here you go.....
https://www.head-fi.org/threads/schiit-mjolnir2-tube-rolling-thread.839972/
down the rabbit hole you go....
xtiva
Oh thanks so much go through thatHere you go.....
tjl5709
Add this one to make that hole bigger................
https://www.head-fi.org/threads/schiit-lyr-tube-rollers.673709/page-1558
xtiva
Lol 1558 pages thanks lots of reading to do heheAdd this one to make that hole bigger................
That is the ultimate tube rolling thread, and the only I would spend time in, if it were me.Add this one to make that hole bigger................
