My home-built tube preamp is on the fritz after 20+ years of use (power supply problem), and I haven't had time to get in there and fix it. After reading reviews (and noticing that former NYC Triode Mafia guy Herb Reichert has one) I got a Schiit Mani to use as a stopgap. I'm happy to report that I like the Mani very much.
My turntable is pretty good. It's a Thorens TD124 with an old Audiocraft AC3000 tonearm, restored for me by James Campbell in PA. The cartridge is a Denon DL110 (high output moving coil).
I was able to dial in the gain for the DL110 very easily. GAIN 1 is set to H, GAIN 2 is set to L. Total gain is then +48dB, which puts the output from the DL110 subjectively about even with the output from my CD player. Input impedance is set to 47k. That was easy!
So, how's the Mani sound? Well... Very nice, thank you. My tube preamp was never all that quiet, so the Mani compares well there. The Mani is very quiet. I don't think the Mani's sound is the
ne plus ultra in transparency or super-clarity, but it sounds very clean. Most importantly to me, it does not have a typical 'opamp' sound. It does not sound thin, washed out or harsh. It sounds quite full; the midrange sounds full-bodied. The high frequencies are smooth and kind of 'delicate,' very non-aggravating. The bass is quick and tight; not overly prominent, but not thin or washed out. The bass from records in my system sounds a little more plump than from CD or SACD, but I don't mind that at all. It could be that the TD124 adds a bit of bass oomph. (I have a Technics SL1200MK2 I could try with it, but haven't gotten around to that yet.)
The one and only area where the Mani might be deficient is clarity and 'detail.' It makes a pleasant, although somewhat simplified sound. You don't hear every little nuance of every tiny sound in the recording. On the other hand, the Mani's sound is completely non-aggravating and easy to listen to. I like that.
I also have a Hagerman Bugle that I built from a kit (original Bugle, not Bugle 2). By comparison, the Bugle sounds a little more tight and quick, with less plumpness in the bass. But somehow the drums sound a little 'drier' or maybe 'thinner' through the Bugle. It's hard to describe these sonic subtleties. (Like "dancing about architecture," as the saying goes.) The Bugle is really good (and like the Mani, especially for the little money it costs), but it has a slightly different sonic signature. 'Drier' describes it, I think. Maybe the Bugle is a little more clear and quick sounding. Maybe it has lower distortion. Maybe it has a more accurate RIAA EQ. I don't know. I'll have to listen and compare some more.
My tube preamp, when it was working, was able to bring out more low level details from the mix, and gave a little more of a 'technicolor' presentation. It made you sit up and notice more. The Mani seems a bit laid back in comparison. Again, easy to listen to. And again, the very low noise floor of the Mani is a nice bonus. You can put your ear to the tweeter and hear almost no hiss or hum at all.
I have not heard the other low budget faves, like the ART, Bellari, Pro-Ject, NAD, etc., so I can't tell you how the Mani compares to those.
So, for what it's worth, that's my impression of the Mani. It seems to work very well in my particular setup. For only $140 including shipping, that works out well for me.
- RG
PS - About load resistance settings... The Mani only gives you two possibilities, 47 ohms and 47,000 ohms. My Denon DL110 works best into something like a 1500 ohm load (its coil resistance is spec'd at 160 ohms), and the DL103 likes something like a 400 ohm load (its coil resistance is spec'd at 40 ohms). Neither of those are accommodated by the Mani. However, if you're willing to rig up a female-to-male RCA adapter, you can solder in the correct load resistors between the signal and ground contacts inside your adapter. Something like this would work, if it can be opened up:
