Question for the Schiit guys- into a 300 ohm load, can you say after how many milliwatts the amp leaves Class A? My guess is ear blowing loud, but I'm just curious
Schiit Magni Headphone Amplifier
- Thread starter Barry S
- Tags
- schiit-magni
imackler
- Nov 17, 2008
Not sure if it matters to your question, but the Magni is a Class AB amp, right?
slantedview
- Nov 3, 2009
What's the recommended power on/off routine for the Magni? Is it similar to other Schiit amps - plug in after power on, unplug before power off? Would I experience a pop or voltage surge if I powered on or off while plugged in?
peepr
- Mar 9, 2011
I keep my phones plugged in all the time. There is a 5 second mute relay switch iirc. Dont get any loud popping or anything.
BLACKENEDPLAGUE
- Jun 15, 2011
of course sponsor factor is an issue.
Push mfr, push
Yeah, this is one thing that's especially true for Schiit equipment, on Head-Fi at least. But the sponsor factor is 100 percent a non-issue.
Got the monoprice RCA cables as per recommended and .. they are super, super tight. They plug in and don't go all the way because all of the outside is slanted toward the middle. Am I supposed to force these in so these go around the plug properly?
Push mfr, push
Jules
- Jan 27, 2006
I have had the Magni for about a week. Just wanted to post some impressions. I'm no expert or anything, I don't have an expensive setup to compare it to, but FWIW, here are my findings. My Magni serial number is in the high 700's for those who were wondering how many have been sold! I have no pot or other issues. Mine operates as expected. Mine was shipped a few hours after I ordered and arrived only two days after ordering. Wonderful service!
The Schitt Magni has a slightly forward presentation with a tinge of brightness. It excels with live music and laid back recordings with greater soundstage separation between instruments. Recordings with compression are simply heightened thereby greatly magnifying their poor sound. Tightly recorded rock music with a slightly forward presentation, as most rock recordings are, tends to have the affect of squeezing the instruments further together, blurring their separation and creating a semblance of an overly bright or forward presentation. I must note that Metallica's Sandman did sound wonderful through the Magni, but I have always found this to be a fairly well recorded album. The Magni excels with laid-back headphones, such as the Sennheiser HD-650, which I used exclusively to evaluate them. I would imagine with more forward headphones, they will sound too bright and focused. The Magni really is like a magnifying glass. I have heard things on recordings that I never knew were there and detail that is unlike what I have experienced without a headphone amp. I use the Magni primarily directly connected to my iPhone via a line out cable, and directly connected to my macbook via a 3.5MM stereo to RCA Cable with volume at around 66% with Amarra as a source. The Macbook, with it's superior DAC, provides a quite livable sound. I have not heard the Magni through an external DAC.
The stringed guitar instruments on various recordings, such as Ryan Adam's Heartbreaker, and Chris Isaak's Baja sessions, have a very round detailed slightly metallic sound which gives the feeling of hearing the pick literally scrapping over the metallic strings and is very punchy and plucky. The vocal harmonies on Heartbreaker's Amy for instance, are clearly recognizable and give a haunting affect and are almost bright. The stringed instruments accompanying the track sit high above the soundstage, with the guitar plugging along the edges of the soundstage, while the occasional drum fills reverberate across the soundstage to amazing affect with great dynamics and punch. Oh My Sweet Carolina also has a great guitar sound and the vocals are very clear and crisp and round, but a bit forward again. In My Time of Need, which is my favorite track on this album (makes me tear up on occasion!), sounds the absolute best with my current setup. The guitar is perfect. I play guitar and know what a guitar should sound like. The vocal presentation isn't quite as forward as other tracks. It's very breathy and airy and the subdued female vocal harmonies are clearly audible.
Evil Ways, from Santana's self titled album, the Mobile Fidelity Sound Lab recording, sounds absolutely perfect. Everything is clear and punchy. This is a highly recommended recording. The dynamic ability of the Magni is clearly put to good use for this track. The punchy guitar, organ and driving rhythm section are all good fodder for the Magni.
Beck's Mutations, the Geffen Records / DGCD 98174 / Canadian Advance Promo - Audiophile Mastering / CD version, is another favorite album of mine. Nobody's fault but my own is quite a conundrum, it manages to sound focused and forward, yet still airy, creaky, distant and soulful.
Swing Live, the 24 Bit DVD version, includes the track Lester Leaps In, and is a good test for dynamics. I would expect the Magni to produce a bit more dynamics, roundness and punch here. There's just something missing. It's as if the Magni has focused in on the mids and high's and lost some of the depth and punch of the drums. But I haven't heard this recording through an expensive amplifier, so I can't comment further here, but the sound is a bit too thin and forward for me. It's almost too focused and detailed, which is a bit unexpected for a live recording. Here, I played with some of the EQ settings and decided to try out the Apple Headphone EQ preset in Amarra. This accentuated the bass a bit and dialed down the high's ever so slightly and offered a much more pleasing sound at the detriment of pushing back the woodwind sound a bit too far into the soundstage.
I will be playing around with the advanced EQ settings offered by Amarra, but for now I am throughly enjoying discovering the Magni.
Massive Attack's Angel is a good track to give the Magni a bass workout. The driving bass line that holds the track together sounds deep, focused, and very good. The rimshots on top sounded good as well, clear, but not too bright. The separation between the various electronic sounds was excellent and I heard details in this recording I had not heard before. The more driving parts of the song sounded great with nice dynamics and detail. The Magni seems to like well recorded electronic music oddly enough. One would think this would sound too bright. But it does like dryer electronic recordings and seems to breath a unique life into them. This track sounds a bit more alive, but still oddly robotic, which is exactly how I would expect it to sound. The cymbal crashes, driving drum sound, guitars…everything sounds great. Wonderful drive, pace and detail.
Emmylou Harris track Where Will I Be, from the album Wrecking Ball, is another track I chose to highlight. I have 16/44 vinyl rip of this album that I enjoy. The drum rhythm that drives this track sounds great off in the left channel. Emmylou's voice is breathy, airy and perfectly staged. The guitar melody is slightly further left of the drums providing a wide soundstage. The bass sits a bit further back and slightly surrounds the other instruments. This track is pure bliss through this setup.
I'm sure there are better amps, but for $100, it sounds very very good. It can be a bit forward, a bit bright, a bit metallic, a bit dry, but it's a very nice amp and depending on what you throw at it, it can sound really really good. I recommend more laid back headphones and more laid back recordings. Even hard rock can sound great through the Magni, just as long as it's not compressed and too forward with its presentation. The Magni really is like looking through binoculars. Focus it in on something beautiful and distant and it will provide some wonderful images, but try to look at something that is too close to you, and it will be overwhelming.
Those are my findings anyway. Hope that was helpful.
Jules
- Jan 27, 2006
I was wondering the same thing and played around with some cheap headphones. I've unplugged and plugged in the the input cables and output cable while its powered and it never popped, at least for my unit. It was dead silent.
ninjames
I get people telling me I say dumb things all day.
The point is that us users/readers don't care who is and is not a sponsor when it comes to our own reviews.
taichicali
- May 5, 2011
Hey all,
I have some AKG K550 headphones on the way to me, and am creating a setup to game (XBOX 360) and watch movies on (PS3). I am wondering if the Schiit Magni and Modi would work (and if it is necessary or helpful) for my setup.
To my setup I plan to add the Astro Mixamp 5.8 wireless and am wondering if I should also get another stand alone AMP along with a DAC. I have a pioneer vsx 1020 receiver, but it seems this is not part of the equation with this setup.
Do I need an external AMP, or is the AMP in the Mixamp sufficient? Also - does the Mixamp have a DAC, or would I want another one of those?
If I did need an external AMP and DAC I would get the SCHIIT Magni and Modi combo - would these have the appropriate inputs/outputs to accommodate this setup? You can see I'm a noob, and I don't want to buy these external units if they won't even work with my setup. Any help greatly appreciated.
peepr
- Mar 9, 2011
Modi does not have optical input for your ps3 and xbox. Would need something like tubemagic d2. Unsure about mixamp stuff.
Greed
- Nov 19, 2012
Not sure if this has already been asked/answered, but I'm wondering how does the Schiit Magni fare with the Beyerdynamic DT 990 600 Ohm version? I'm looking for a good transportable amp that I can use with both my travel companions my DT 990s and Senn 650s. I've already read plenty on the synergy between the HD650s and the amp, but haven't seen anything about the DT990s.
cheuh
- Oct 9, 2012
Can anyone compare the Magni vs O2?
I would love for others to compare the magni/modi against the o2/odac besides me. It'd be interesting to hear what they have to say about them. One thing's for sure though, any possible hyperbole about the comparison is just that-- hyperbole, and those are not different characteristics anybody should worry about at this entry-level price point if said differences are so subtle.
slantedview
- Nov 3, 2009
Any popping/noise when turning on/off with the headphones already plugged in?
slantedview
- Nov 3, 2009
http://www.head-fi.org/t/642401/comparison-and-review-o2-odac-vs-magni-modi
I think there was one other comparison as well and they found them very similar.
peepr
- Mar 9, 2011
I dont experience any
