imackler
- Nov 17, 2008
Thanks for the advice/questions guys! Can anyone confirm whether I can always leave my headphones plugged in? I always took it that with all solid states, whether relay or not, and not just Schiit, safest practice was to plug in and unplug while the amp was on, and not to leave them plugged in while turning on and off the amp.
There are no dumb questionsIt was actually a good question IMO. I think it'd just be the same, the current/shock would go to the plug first, so nbd. It's a problem if that extra voltage goes to the drivers and washaws them. But I don't see the real difference in time of taking out the 1/4. If you have to screw it out/in I'd just take out/plug in the jack.
Ya I don't see why not. The magni has protective relay when turning it on, so you could leave anything plugged into it. I even left cans plugged into my other amps, but I always lowered the volume pot before turning on and off.
So it is considered most safe to insert and remove headphones when the amp is on?
