Mingus Ah Um
- Aug 20, 2011
Well, when I plugged my Modi into my computer, and set the sound playback device to the Schiit setting, it automatically adjusted my computer's volume to max for me. However, it's probably worth checking to make sure that happened.
You should also turn the volume of your audio app to max, and use the Magni to adjust volume. The only time I wouldn't turn the audio app to max, would be if you have low impedance cans, and you have no volume adjustment on your Magni.
I would also open the Sound settings from Control Panel, and make sure there isn't some setting lurking in there that's been turned down. For example, on the Custom tab, there is a single choice with a check box called "Limited Output". You want to make sure that isn't checked. On the Levels tab, there is yet another volume control, and if you click the Balance button, you'll find two more to adjust per-channel volume. On the Enhancements tab, I usually check "Disable all sound effects" - some of those sound effects can lower the output volume. Finally on the Advanced tab, I make sure both boxes in the exclusive mode section are checked.
Finally, make sure you're using good cables. If you can swap both of them with other cables, that would be worth a shot.
Thanks for the help Kidn. Most of the steps you described I went through last night. Still no go. I even tried it with two other computer and still wasn't getting the sound output I should be. One thing I didn't think to try was change the cables. The cables I'm using haven't been used for quite a while but I don't think they are bad cables necessarily. I'll try swapping them for another pair tonight and see if that works.
When I plug the M/M in it doesn't do anything to my system volume. I go in an manually turn it all the way up. I had read elsewhere on here where people favored setting the computer volume at 25-50% and letting the Magni do the rest from there. If I try that I have to turn the Magni up almost all the way to get loud. I personally think the settings on the computer are fine as evidenced by the e7/e9 combo working when I hook it up. I'm guessing at this point it could be crappy cables or possibly a problem with the amp itself. Thanks again for the input.
