sfo1972
- Dec 9, 2014
Ask for a picture of the codes - usually on the bottom of the tube and printed/etched on the side. When the silkscreen is wiped as a result of handling, as can be seen from the picture, the codes are usually the best source of recognizing if this tubes is what the seller is advertising.
+1 They are hard to spot sometimes. I find a good halogen desk lamp works great and holding the tube at an angle rolling to spot the codes. Sometimes all you can read is the etching reflected.
Something like this:
http://www.amazon.com/Living-Accents-Halogen-Architect-Adjustable/dp/B0044FZ5SE/ref=sr_1_5?ie=UTF8&qid=1428650088&sr=8-5&keywords=halogen+desk+lamp
