billerb1
What age do you guys think these are from?
http://www.ebay.co.uk/itm/2-x-ECC88-PAIR-TUBE-PHILIPS-NOS-TESTED-TV7-EQ-MULLARD-CV2492-E88CC-6922-6DJ8-D3a-/291360681786?pt=UK_Sound_Vision_Valves_Vacuum_Tubes&hash=item43d6732f3a
In the description they guesstimate that they are 60s but a confirmation would be great. If they are I might grab them as Miniwatts seem to have the warm smooth trebled sound I am looking for, similar to Mullard and Voskhod tubes. Thanks again to everyone that has helped me on my tube quest so far!
I would recommend holding out for E88CC or preferably E188CC Philips Miniwatt or Valvo, making sure they are from the Heerlen factory (delta code), 1965 or earlier. That "dimpled getter" and the 1969 date would scare me. If you keep your eyes opened you can often get the E88CC's for $75-$100 and even get the E188CC's (my favorites) for under $100...certainly under $150. It's worth it. Just make sure you check out the date and origin codes and test results. Also ask if there is any tube noise (hum, hiss). If the seller isn't forthcoming, stay away.
Good luck.
