TK16
400 hours on this set. They been long burned in.
I’m still burning in my 6N3P single post getter and have them around the 80+ hour mark. They sounded different from when I initially got them and now they’re slowly opening up more. Once I get the MJ2 back from Schiit I’ll keep putting more hours on them.
I received the second Telefunken E188CC and paired them up that’s when the MJ2 died. I’m not one for conspiracies or bad karma but I think the Teles are cursed.
Could be a shorted tube. Did you find out what was wrong with the mj2?
Thought it might be. Swap out your interconnects, and test those tubes for shorts before plugging it all back together.Schiit support got back to me and said it was a blown fuse. So at this point I purchased a new power cable and a Furman power conditioner. If it dies again I guess it’s not a crappy power grid but something else.
Hope to have it back soon.
Just plugged in my pair of AFO`s with a Black Dragon balanced cable. Sounds freaking fantastic, PS. do not buy out the remaining supply of late 40`s to early 50`s versions. They were recalled due to an ebola breakout, if you have any send them to me so I can "properly dispose" of them.Man the WE 396a's a great with the HD6xx too. Usually I either like a tube on the LCD2c or the HD6xx, not both. These things are amazing! Ok I'll stop gushing about them now
Extremely warm combo, quite a nice change of pace from the more neutral tubes.
Let us know what you think...
I've had luck in the past with using a tube I don't care so much about, and bending the pins outwards a little so that it fits really tightly in the adapter, and then some gently wiggling until it lifts. Some of the old ruskies have fatter pins, so using one of them, and bending the pins outward a touch worked best. Didn't always work though. Had to use needle nose pliers on a few occasions. I've since double stacked with savers and adapters on the stubborn pair I have, so I don't end up there again.Took me a while to get to reply however here's my findings:
After quite a few days testing (saga was on 24/7) with a single Telefunken E88CC 1960s Fat Getter in the Saga it sounds great, has a bit more gain like that which is nice, have not noticed any negative effects BUT one issue is that the adapter is very sturdy and fat, so it's currently stuck in the amp. I pulled out the tube and the adapter didn't come out with it.
I'm sure I can pull it out using a string of some kind that I wrap around it but still it does not come out easy, for now I personally don't care as I don't have any 6SN7s and I don't plan on getting any anytime soon.
So to sum it up -
Pros :
+ tube worked
+ sound was nice with more gain - the tube did not affect it as much as if the same tube pair in the MJ2,
+ no technical issues
+ adapter is nice and solid
Cons:
- Adapter did not come out with the tube and is now stuck in the amp so needs special care to remove using a contraption of a wire/or string around it OR amp disassembly.
Here's a picture showing the adapter in the Saga:
Nice tips Seeing you reply I just got an octet of Foton 6N3Ps There's 1x1963, 2x1964, 3x1966, 2x1968 so gonna test and match them now as close as I can based on years. Funny part is half of them are labeled В82П (V82P) not sure why but the same years have exactly the same construction as the ones labeled 6Н3П (6N3P) so I believe they are just mislabeled. Also the interesting thing is the typical russian "saucer getter" is actually square and not circle on the ones from 1963 and 1964. Fun stuff!
So to sum it up -
Pros :
+ tube worked
Cons:
I still think the Reflektor E’s are some of the finest inexpensive tubes out there and compare and surpass many others that are 10-15 X’s more expensive. But I still really like the rockets and especially the Fonton’s. It’s great being able to get great sounding tubes for less then a freakin candy bar.
