I've just made a similar transition. Replaced Asgard 2 with Jotunheim with Bimby as input.
Can't say how Jotunheim will compare with the LC v2, but Jotunheim > Asgard 2 in every way that I can tell. It is a fabulous combination.
Edit: forgot to mention - using SE HD 600.
Edit 2: Only problem is that this now sounds better than my "primary" stereo speaker setup.
Wow. Ether C Flows with Asgard 2 from Bimby already win over my speaker setup in some respects: less smooth, more real percussion, sax, and strings, maybe because of the integrated DAC/amp Bel Canto C7R powering my speakers, which tends a bit towards the mellow, great for dinner time music but sometimes less convincing in close listening. I fear that the Jot is going to "force" me to replace the C7R by something else (hum, Schiit two-channel...).
Yoe-tun-highm (Jötunheim) should be the correct Old Norse pronunciation, seeing as Schiit went with the anglicized version then Yoh-tun-highm is probably the most accurate approximation.
The mjo1 had plenty of power but was harsh sounding especially in the treble spectrum. It needed a warm dac to yield a pleasing sound. The mjo1 never worked for me.
The mjo 2 is a fantastic amp. With a good set of tubes, this is an end game amp for just about anyone. Tube sweetness, unapologetically dynamic, refined power. Very natural and organic sounding. The thing I have to be careful with is going down the rabbit hole called tube rolling. You can easily put up 1/2 the cost of the amp for a rare set of tubes. A collection of tubes is often more than the cost of the amp itself.
