At first I am planning to get Mjolnir 2 pair with Gungnir multibit, but after reading a lot about tube amp (I never had experience with tube amp) I was a bit of scared, the idea of tube rolling is scared me. So instead I am planning to get Jotunheim amp (Ragnarok is out of my budget) pairing with Gungnir. What do you guys think? Any advice will be much appreciated, thanks.
Schiit Jotunheim Review / Preview - Head-Fi TV
- Thread starter jude
I don't want to talk you out of getting Jot but Mjolnir 2 with stock tubes is just fine. You can also purchase the LISST tubes as well for an all solid state amp. IMO, people spend too much money tube rolling, I speak from experience spending over $400 on tubes for an amp costing $300.
Yes but people on the Mjolnir 2 forum and review seems to dislike the LISST tubes, its not as good as dedicated solid state amp and in this case some people prefer Jotunheim over Mjolnir 2 with LISST tubes.
This is what I am afraid of
What are your headphones? Do you care about soundstage or do you just want quick transients, good bass and a slightly brighter sound? Jot will do well with darker headphones like the HD650, really brings them to life. It has great driver control but it lacks in sound stage depth and can have a treble glare or slight edge to the sound that never completely goes away.
I am using Focal Elear pairing it with JDS LABS El DAC/AMP stack. The El DAC/AMP is my first desktop setup and Elear really sound good with it compare to my portable setup (iBasso DX200). So I am just curious how much Elear will improve when I am pairing it with a better desktop setup.
Tuneslover
I agree that you don't need to buy too many tubes to get a good cross section of how a tube amp sounds. I bought 3 popular tubes for my Vali 2 to replace the stock tube over the last 2 years. They sound very good with my Project Ember too, so does the very nice 12V tube that came with it.
tuna47
I was a tube roller for a while. I enjoyed it but got carried away can get expensive
I have the he1000 which I feel is better with solid state so use the jot
I would buy a tube amp again but just purchase one set of upgrade tubes
litwick87
- Nov 7, 2009
Anyone use the saga tube preamp with the Jot to give it a little tube sound?
Tuneslover
I have an HD650 (with balanced cable) and will be getting the HD6XX (with standard SE cable) when Massdrop ships them in December. I was wondering if the Jotunheim is able to capably run both headphones simultaneously? Since both headphones are 300 ohm they should be roughly the same volume. Actually the balanced set should be a bit louder but that's ok.
Totally agree with this. As much as I love my Jot, if it's paired with brighter sounding headphones, it can definitely become too much of a good thing. The Lyr 2 is also an amazingly great sounding amp (even with its stock tubes) and I actually prefer it in many respects over the Jot. I plan on getting the Lyr 2 as my next amp to compliment the Jot, because sometimes I want a slightly richer and more vivid sound than the Jot provides.
The Jot is like Sparkletts ultra-filtered water, while the Lyr 2 is more like Arrowhead mountain spring water. They both are pure water but each one has its own unique subtle flavor.
litwick87
- Nov 7, 2009
Been using the Jot all day for different genres and even a little gaming. I love this thing with the 650s. Night and day difference from just out of my laptop. Eventually I'll "upgrade"? to the Bifrost Multibit for a DAC, but for now i love it as-is.
If I were to get one of Schiits tube amps, how would I set it up?
Jot DAC->tube amp and just run my headphones off of it? Or would I need a whole new DAC?
If you have the USB DAC for Jot you can use the preamp outputs and send to a tube amp. Put the volume on the tube amp to 3/4 and control the volume with Jots pot.
litwick87
- Nov 7, 2009
I'll keep this in mind, thanks!If you have the USB DAC for Jot you can use the preamp outputs and send to a tube amp. Put the volume on the tube amp to 3/4 and control the volume with Jots pot.
litwick87
- Nov 7, 2009
Wow, the Jot did more for my powered monitors than I ever would have imagined :eek3:
Total: 9 (members: 0, guests: 9)
