The Jot has a TON of power at it's disposal. If you're using sensitive IEMs or even headphones, you will hear the noise floor of the amp as the gain is too high for that particular headphone/IEM. I almost always run Jot on Low Gain as the noise floor is lower.
To test if it's the amp or the music, is pretty simple. Does the noise still exist when there is no music playing? Is it constant? That means there is too much gain or your headphones are too sensitive. You can confirm this by disconnecting all cables from Jot except your headphones and power cable obviously.
Like both you and Bacon Bits stated, it's not the amp. There's black background when I pause any track. Damn, what's the odds of having 3 very sensitive HP's? I thought at least the 650's wouldn't hiss but they do. Now I got to figure out what to listen too that doesn't suck with how they laid the tracks down. It's everything.....damn. So much for nirvana.
I always run the Jot on low gain as it's got plenty of power and most times I'm between 12 O'clock at 2.
Thanx for the replies guys.
