MWSVette
I believe there's something wrong with these cans as there's hardly any bass.
This was the part of your statement I was referring to...
To be blunt: all the hocus-pocus about "pairing" is really about asking the amp to fix headphone weirdness or match user preferences for spectral coloration or "euphony" (aka even harmonic distortion). The big "sin" of the Jot is that it is pretty close to a "wire with gain" and so does not bend to all of those needs. On the other hand, it comes closer to my frequent experience of live music than for example the Liquid Carbon (just listening -- see headphone system info on my sig below -- to a new live recording of Bill Frisell and Thomas Morgan at the Village Vanguard, and having been there myself and listened to Frisell live many times, I can't find any fault with what I'm hearing). Nothing wrong with seeking an amp that tweaks the signal to match your transducers and preferences, but blaming the Jot for being closer to the signal truth is akin to blaming the messenger for the news.Why are you defending the Jot by making exceptions? The Jot is not a bad amp but it depends on the headphones that one has, the individuals hearing, preferred genre, and many other factors.
Cool. Got it.
So let me ask you, what amp/DAC are you running with? I'm just not getting the bass with my current set-up. As I was saying, all my other HP's have more bass then the TXH-00's so I'm thinking there's gotta be something jacked up with the pair that I own. I use the same set-up with all my cans and these have the least amount of bass.
I'm also thinking an upgraded DAC may pair well with the new Purplehearts/Jot. Yes? No? Maybe?![]()
I use my Jotunheim with a Modi Multibit, feeding my HD650s in balanced. It doesn't sound bright to me and I do have a bit of treble sensitivity. To me this setup sounds absolutely fantastic.
I own a Jot with DAC module, Mimby, and Bimby with the HD650 headphones. To me, the tonal balance and characteristics throughout low, mid, and high frequencies is fairly consistent between all 3 DACs. The biggest difference is the soundstage and separation increasing with the Mimby and slightly more so with Bimby. It is more noticeable with good recordings, with the difference between Jot DAC and Mimby about 2x greater than between Mimby and Bimby (Law of diminishing returns). Bimby does seem to have a slightly warmer sound overall compared with Jot DAC and Mimby and is my favorite of the three. Value-wise, you won't be disappointed with Mimby.To those who own both the Jot with DAC and Mimby, how much of an upgrade in sound quality is there while going from the Jot-DAC to the Mimby. I am trying to decide whether to spend $200+ for a dedicated DAC. Which are the areas where you see improvement. Is there a wider/deeper soundstage. Are the notes more prominent? Is the bass more visceral? Most importantly, will there be a readily detectable improvement in SQ or is it more subtle?
I hate to ask this, after so much has been discussed, but I couldn't find the answer to my question in this thread. Many people have stated there is going to be an improvement in SQ in Mimby, but I am looking for a more critical assessment.
Thanks in advance.
anyone here tried driving hd800s with jotun?
thanks
There are people here who uses HD800S with Jot but I never like this pairing, let alone 800 non-S version. The paring only exacerbate the high mids/treble issue. Unlike many others, I don't find Jot all that amazing. My definition of a good amp is that it does not add coloration to the music, and in the case of Jot, the treble glare is very obvious. I also find the clarity of the Jot unnatural. I was comparing the sound of phones directly plugged to the RCA of mimby and mimby->balanced Jot, and every time I find the chain with the Jot having more clarity. How is it possible that adding an additional equipment in the chain will make music from the DAC clearer? The sound feels like it has been smoothed over at the expense of small fine details, much like an antialiasing applied to make things cleaner and smoother. I supposed the pricing of the Jot is good, and that is at least a good point about it.
Jot with or without DAC? My experience with Jot fed by two very different DACs (Bimby and Holo Spring KTE 3), into MrSpeakers Ether C Flow or Æon, is very different from yours. No coloration whatsoever, realistic clarity, remarkably close to my very frequent experiences of live jazz and classical music. My sense of Jot criticism is that many people want their amp to drive their headphones to create a particular target sound profile that is pleasant even if not necessarily live-realistic, and the Jot fails to oblige by being honestly true to the source and thus incapable of overcoming recording or headphone peculiarities. I kept a Jot against a Liquid Carbon because while the LC was more pleasing at first, it sounded ultimately less true to the sources. The only solid-state amp I've heard that I prefer to the Jot -- for better instrument separation and sound stage -- is the Neurochrome HP-1, which I just got after I did a side-by-side comparison. Not a huge difference, so I'm keeping the Jot for another system. Of course, I've not listened to everything out there. And a Rag would be too big for my headphone amp locations.There are people here who uses HD800S with Jot but I never like this pairing, let alone 800 non-S version. The paring only exacerbate the high mids/treble issue. Unlike many others, I don't find Jot all that amazing. My definition of a good amp is that it does not add coloration to the music, and in the case of Jot, the treble glare is very obvious. I also find the clarity of the Jot unnatural. I was comparing the sound of phones directly plugged to the RCA of mimby and mimby->balanced Jot, and every time I find the chain with the Jot having more clarity. How is it possible that adding an additional equipment in the chain will make music from the DAC clearer? The sound feels like it has been smoothed over at the expense of small fine details, much like an antialiasing applied to make things cleaner and smoother. I supposed the pricing of the Jot is good, and that is at least a good point about it.
I see, thank you for your input.
I'm considering buying jotun because of the price tag lol
