sludgeogre
- Mar 13, 2014
Everyone needs to calm down on this whole balanced debate, this will never get figured out here. If an amp or DAC was designed to be used balanced, it'll probably sound better in balanced mode. If balanced mode is offered just for convenience, you should expect no difference. If the balanced signal can be generated into an amp without much change in the signal, then there probably won't be much of a difference. In the case of the Jot, since only half the amp is used in SE output, but the whole amp can be used with an unbalanced or balanced input through the balanced output, but will provide more power through balanced output, it really depends on the headphone. If it's a "power hungry" headphone then it should sound better through balanced output. If it's a very sensitive headphone, it's highly unlikely you'll notice any difference from the added power. If you want to talk about noise floor and all of those specs, fine, but inaudible is inaudible is inaudible. I don't care if the balanced output has less noise that I still won't ever hear and it's crazy that people still argue these points. I'm exhausted.
