- Jun 29, 2014
I usually oiled my cable when I received them...it gives a smoother sound and make transfer of data much faster
I dunno much about USB cables in the audio world. But one of my clients is a VAR, selling/installing/supporting audio visual equipment, IP video surveillance equipment, and video conferencing equipment. Some types of digital cables do affect quality of video. I'm not talking analog signal cables, I'm talking digital cables. I'm also not talking about USB cables, so my two cents might be meaningless.
But...anyway, in the video teleconferencing world (mostly H.264 or MGCP and G711/729 for audio), or in the IP video surveillance world (now more and more H.265), the phrase "a cat 6 is a cat6 is a cat6" doesn't fly. ComScope's low end cables dramatically affect video and audio quality, and their higher end Systimax cables, when comparing the same category ethernet cable (generally cat6, though the comparison works with cat5E also), always perform better. Significantly better.
Dunno if that applies to USB cables, but just because a cable is sending digital data, doesn't mean they're all the same, that's for sure.
Either way, seems from reading comments that this is a fairly common controversial topic. But for me, at least, all this talk wasn't totally pointless for the Jot thread. I will purchase a better USB cable (not a $150 cable, way outa budget for me, but maybe at least PYST cable). $20 is worth it for an experiment.
Thanks for the info and different perspectives.
HD video bandwidth probably becomes an issue, won't be an issue for 2 channel audio on USB.
Is that because the distortion due to EMI is simply too little to be audible?
i imagine the distances can be quite a bit longer. Most people here aren't going to use a cable more than what like 10ft? 20 ft tops? i imagine a lot with what he's doing could be like 100 or 200 ft, maybe more.
Apologies if this has been covered, but a thread search was unsuccessful.
Has anyone used an (iPhone or iPad) > CCK > USB on the Jotunheim?
If so, any impressions or problems?
So what? Digital is digital, bits are bits, yada-yada. Right? They survive forever and over an infinite distance. Right?
I presume you're all RF engineers here. Right?
