Steely Dan
- Nov 7, 2007
Just got my Fulla 2 last week, using it with HD650s, so far it's been a noticeable improvement over the FiiO E10 I previously had connected to this PC, and also solves the channel imbalance issues at lower volumes I had with that amp, although it's still noticeable at the lowest end of the volume knob. Also had the pretty tight USB port fit. Other than that very happy with the amp. One question I have is about the DAC only line-out. With my E10 I used the line out to connect a Yamaha receiver, and just left it plugged in at all times. Is there any reason not to do the same with this setup? Testing it I've confirmed that both headphones and the DAC only line out both work at the same time, so it's just a matter of turning on my stereo and turning down the volume dial to mute the headphones when I switch. Any down side to doing this? I'd prefer not to be constantly unplugging the line out.
