Made it !!!
100 pages, baby!
with headphones sennheiser hd238 precision, i do not feel much difference between the hangover 2 and the audio embedded on the chrome book, it depends on the headphones?Soundblaster ZX is a card for installation on your PC with an external amplifier / volume control and software. It also supports 5.1 sounds like the most modern sound cards. It's completely different from a small DAC / AMP stereo that is geared to a quality sound - but above all as a stereo amplifier for stereo headphones. So if you're looking to build a surround sound environment on your gaming PC, the ZX (or something) is the way to go.
The Schiit Fulla 2 is a small portable device that works with the power provided by the USB data connection (if the connected device can do so). I got the upgrade on a 5 year old Realtek DAC motherboard on my PC but also wanted something small to use with my phone to improve the sound of that device (or my Chromebook or laptop). So it's very easy to use FULLA 2 for exceptional sound on any USB-connected device. But there is no unique software at FULLA 2. It's a headphone amplifier and a preamp. It will not directly guide passive speakers.
Schiit Audio uses high quality components to implement its high quality and useful designs. I did not see any detailed specifications on Creative ZX to be compared. If what you're looking for is a good sound for stereo headphones, FULLA is a cheap way to get started. And it can be used with any source device that can provide a USB datastream to a host (PC, phone, laptop, Chromebook).
Fulla agree! Using mine now since May 2017 with AKG K551 and excellent sound to my ears. Only issue I encountered is that you need a correct adapter for the K551 mini-jack plug or use the line out on the fulla2. Highly recommended!I just bought one. I completely love it. No QC issues so far on mine. Sounds fantastic. I feel like it was $100 well spent for sure.
Had the same problem with my IEMs.the fulla 2 gives loud hiss to my westone es5, if you also want to drive iem and headphones, FiiO e10K is better IMO. It does look gorgeous though, can't stop looking at it
Ehi! I got a simple question and I know I could find the answer in the 3D but there are 100 pages, baby!
Made it !!!
100 pages, baby!
Magni3 has more output power. Doesn't need a TTRS adapter and uses a Current-Feedback topology with a lower noise floor.Ehi! I got a simple question and I know I could find the answer in the 3D but there are 100 pages, baby!
I've bought He400i (actually He4xx), what's the difference between magni3+modi2 and the little I-do-it-all? I ve seen you in the m3 3D too
The HE-4XX is already TRS so it doesn't matter for the Fulla 2.
Just a heads up on the DACport Slim - it has a pretty high noise floor which can be audible for cans up to around 32 ohms. However I think it sounded better than my Fulla 2 when paired with my HD-6XX. There are a lot less features than the Fulla 2 though, so the Fulla 2 won out for me. No channel imbalance on the DACport Slim, but there is still audible stepping due to digital volume control having a defined amount of steps.
I've resorted to lowering windows volume to 70%. Theoretically the decreased bit-depth should have little to no effect because most of my music is 16-bit 44.1khz. It gives me more room to adjust volume outside of channel imbalance ranges.
Not ideal but until something else comes up with the plethora of features and a nice specsheet like the Fulla 2, it'll do for now.
Hey everyone, I posted in the HD650 thread but I thought I could ask here as well.
So I've got a pair of HD650 and a Fulla 2 to drive them. I've read a lot of posts about this pairing and I'm seeing some very different views on whether it is enough to power them decently.
It gets extremely loud but I guess it's all about sound quality rather than loudness. Do you think it might be a better idea to replace my Fulla 2 with something like the Magni 2, although I might have to wait a bit before I can invest in a separate DAC? My on-board Dell audio isn't great so I am wondering whether it will be fine with just an amp for the time being.
