That review is pretty lame in addition to it being rendered instantly irrelevant, but that can't stop me from ranting a bit: Tubes run hot? Really...they're TUBES...the power switch is so easy to locate (my stuff is turned on by a power conditioner, but if I want the tube pre and power amps off and other non tube items left on when I'm out for a bit I reach in there and hey...flip the damn switch...) this can only be seen as a silly quibble. Man...I'm sort of amazed that after all the user reviews and Schiit's own comments that anybody feels the amazingly well designed relay switching volume clicking is an issue as it only makes noise when changing levels...and if tubes are so microphonic that this affects them (which I seriously doubt it can) you're using very bad tubes. By the way, wondering where the volume is on the older Freya relative to what you might have adjusted with the remote requires listening to it, and that design works swimmingly requiring one to turn the knob to where the remote level was before manually adjusting the level...is that really an issue? Hmmm....I keep my "original vintage" (owned since 12/17 or something) on a lot, it doesn't burn through tubes, and I've assembled a pile of 6SN7GTBs anyway because NOS GEs (my fave for this preamp, and there's one in my little single ended power amp) are relatively inexpensive...generally less than new Tung Sols by the way. The issue of warm up time is also pretty funny as, again, they're TUBES and the Freya warm up takes what...40 seconds? I think one buys the Freya because it's a tube amp, and now you can buy one because it's not. It's also not 4 thousand dollars. I don't leave even my non tube gear on 24/7 as I can wait for warm up and don't trust gear to take care of itself. The guy with the Freya+ shipped with a loose LED lens perhaps should have immediately sent it back for a fresh one, although the non-screw case design is kinda strange...glue? Welded? Some inner clamping system? Schiit maybe just dumps flawed ones as they do with their very inexpensive stuff, but I generally open new gear just to look at it (or in the case of my Freya to dim the LEDs) so, meh. If I need a preamp for a second system someday (although I still have the balanced, dual mono, 30 lb SS pre the Freya replaced) I'd buy the Freya+ in a heartbeat mostly because, luckily, my now "classic" version works perfectly, runs humlessly, and sounds fabulous.
