davide256
- Aug 13, 2010
With better gear you get into increased mid range resolution, improved dynamics and solid vs weak tone color... what you describe is just the start of the journey.You are not going to be hearing a whole lot of difference for the most part. It could be that your Audi-Gd has a very good USB port. Listen for low end frequency tightening and cleaner high frequency detail, those should be the area's you should hear the most, if any differences.
I'm
I'm listening to it right now with Tidal Lossless Audio player, Miles Davis's SO WHAT.. and to be honest not getting that initial WOW.. this was worth $200! Does this have a burn in period? And I am tired so maybe need to listen with that morning cup of coffee that or my Audi-Gd 11.28 has some descent parts inside.. Got 15 days..
What are you using for a source? The Eitr can't fix source clocking/power supply weaknesses... experienced that playing around with Allo USBridge using their stock SMPS.
