spaceace1014
- Jan 17, 2013
The iPhone can probably electrically see the Bifrost just fine but the Bifrost probably has its own machine language.
Say you were calling someone to order a pizza Your Iphone is you and the italian guy in the dirty little pizza parlor is your Bifrost. This guy who is fresh from italy(your Bifrost) gets your call and you say hello and he thinks maybe your his cheese supplier and he starts gibbering at you in italian and you try to stop him but he doesn't understand a word your saying so finally you hang up (that's an error). Your Wyrd or a direct cable are analogous to the phone. The phone made a perfect call but you weren't able to order a pizza because your phone and your Bifrost speak different languages which in computer terms is called a driver.
I can confirm that the Wyrd in general will work with an iPhone and if you can confirm that the actual Wryd you've got on hand is actually functioning in a simple scenario by connecting your Bifrost through it to your computer than the problem most likely lies not with the iPhone and not with the Wryd and if that's the case the most likely culprit is the Bifrost.
