I need some help with an issue I got with Lyr:
I've always used no-breaks into anything electric (good, hight wattage APC ones, always) all my life and never had a problem, I hate when I something I'm using is just turned off by any kind electricity problems (line failures and such). With the Lyr tough, whenever the no-break goes to battery mode, it just starts this strange static noise (that continues until the energy gets back and the no-break goes back to line mode).
NONE of my various other audio equipments ever showed any problem with batteries. I wonder what can I do to fix this and use the Lyr with the no-break on battery mode with ZERO static/distortion.
I've already tried an Ortofon AC-4000Q and an Audioquest NRG-4 power cables with the Lyr in all my various no-breaks and it changed nothing... Whenever the Lyr is powered by a battery, it starts allot of static noise trough the Headphones.
Please, help me with this one!
Thanks!
The answer is very simple. Most UPS devices don't generate a very clean sine wave. (They're intended for computer equipment, which simply isn't that fussy. Computers are perfectly happy with anything that even vaguely resembles a sine wave.) The noise generated by the APC is simply getting through the power supply on the Lyr, whose filtering just isn't good enough to eliminate all of it.
Unfortunately, power cables DO NOT filter out line noise. That is a myth propagated by the marketing department to get your money
At most, a really well shielded power cable could prevent noise from leaking in from some external source (like if you lived next to a radio tower), but a power cord will not, even a little bit, remove noise that comes in the end with the power. (There is a very remote possibility that a power cord could help if the noise is leaking out of the wire and being picked up by the tubes, and so bypassing the Lyr's filtering. For that you could TRY a nice $12 shielded power cable intended for a computer monitor. It probably won't help, but it might, and you're only out $12.) What you need is an actual power filter. Even some power filters may or may not help - it sort of depends on the design of the filter and the actual specifics of the type of noise. You need an actual FILTER (aka a noise suppressor) and not just a surge suppressor.
(A surge suppressor is designed to protect your equipment from dangerous surges and may not be so good at removing plain old not-dangerous noise.)
Honestly, unless you have lots of power outages, the obvious easy answer is to stop running your equipment off the UPS. UPS's simply aren't a very good source of clean power.
If you're into DIY, then you could easily build yourself a nice power filter (think inductors on the line and capacitors across it). There are decent commercial ones, but I don't know offhand which the decent ones are and you could spent a lot of money for various "audiophile" ones that are not all all useful or helpful. Any true power REGENERATOR should put out a clean sine wave, but they tend to be rather overpriced.
kLevkoff
