Orange5o
I am not that handy, so if anyone is dying for a 2/64 card make an offer lol, was thinking of going back myself
The card in the picture is actually 2/64.zexk, I would use the same caps but if I remove them from the OG card, the leads will be really short and hard to work with, and also I'd rather risk ruining one card than both. Anyway, I got six Nichicon Fine Golds for $13 on Amazon. I'll let you all know how it affects the sound in a few days...
Orange5o - yeah, I've gone back and forth for months. I get that the 2/64 card has better detail and maybe a bigger soundstage, etc., but it just isn't as engaging.
That's part of it, but also I have some mild tinnitus that has constantly led me towards warmth. Switched from planar to dynamic, then led me to Yggy LIM in my speaker setup, and now everything I power has 1-2 stages of tubes. This is part of it.zexk, I would use the same caps but if I remove them from the OG card, the leads will be really short and hard to work with, and also I'd rather risk ruining one card than both. Anyway, I got six Nichicon Fine Golds for $13 on Amazon. I'll let you all know how it affects the sound in a few days...
Both are not really warm sounding DACs imo. They're are more neutral sounding. You might want to seek out a used MM1, Bifrost 1 Multibit or BF2 OG if you're looking for warmth.Hello:
Looking for some advice on the choice between two dacs:
I've been a fly on the wall for a long time now regarding the purchase of one of Schiit's dacs; then they went missing in action for a while now they're back.
I have a simple 2 channel system whose main listening use encompasses the playing of CD's, audio files, internet music/movies etc. Here's the thing, I'm wanting a relatively warm sounding dac and my choices narrowed down are between the Modi Multibit 2 and the Bifrost 2/64. If there is anyone that could speak to this, I'd be grateful as it is an expensive endeavour if I get it wrong and have to send it back as I'm not from the US of A.
I know this question is subjective, but I relish opinions and would be happy with any input.
Thanks. Look forward to hearing back from those who would be willing to chime in.
Cheers.
@2bxfile I've never listened to the MM2 but I have a good amount of experience with every other DAC mentioned above and can confirm I agree with the statements about those DACs.Both are not really warm sounding DACs imo. They're are more neutral sounding. You might want to seek out a used MM1, Bifrost 1 Multibit or BF2 OG if you're looking for warmth.
Then again, ppl do sometimes sell the OG BF2 card for not too terribly much. If the 2/64 didn't feel warm enough to you you can easily swap out the cards yourselfThanks to you both. I guess neutral sounding is closer to what I'm looking for as compared to them being bright, although I have read others describe the Bifrost as a bit crisp and bright to the ears and the MM2 as a bit dark.
I think the best decision would be to order the less expensive one - better to be disappointed with less money out of pocket than more than double.
Thanks again.
Then he is just wasting money at that point, assuming he ends up not liking 2/64 board. Used BF2 OG can be found for around 500.Then again, ppl do sometimes sell the OG BF2 card for not too terribly much. If the 2/64 didn't feel warm enough to you you can easily swap out the cards yourself
FWIW, he did say neutral was fine. I would describe the 2/64 as pretty neutral. Of course, used will always be less, and it's not necessarily a waste, particularly if you buy used and then sell, but he did say he wanted to buy new.Then he is just wasting money at that point, assuming he ends up not liking 2/64 board. Used BF2 OG can be found for around 500.
Look at one of my previous posts. I have screenshots of two BF2 OG cards. I believe BF2 was released in 2019. 2/64 was released last year.Thanks guys - you are generous with your help. Can you tell me what the BF2 OG has inside and how far back it goes in the Bifrost lineage?
I believe the OG BF2 came out around late 2019 or early 2020. Uses Analog Devices chips as opposed to TI on the 2/64. The OG BF2 was the 1st Unison equipped DAC.Thanks guys - you are generous with your help. Can you tell me what the BF2 OG has inside and how far back it goes in the Bifrost lineage?
