HighFiguy
- Mar 8, 2012
Is there anything I should know on the Asgard being a 115v or 230v? Any differences?
Is asgard and akg q701 a good combo? I only have the e9 right now
That is bad news for me about the HE-500, as I was seriously looking at getting a pair with my current setup. With a 38Ω impedance, and the Asgard's apparent 1W into 50Ω, I figured there would be plenty of power for these cans. What is the voltage output of the source you are using? The specs on the LD MK II show only 100mW into 32Ω and 200mW into 120Ω, so I would have expected the Asgard to be much more powerful using the same source. I know the sensitivity of the HE-500 is very low, so perhaps the issue is one of lacking voltage, as I assume that the current is more than adequate with the Asgard.
Hi there -
I'm thinking of buying an Asgard which would mainly for use with the Sennheiser HD 800. Has anyone here (apart from Jude) heard that combo?
If I added the Asgard to my Lavry DA10 and HD 800 chain, would it affect the sound much or just be a very slight difference?
Thanks,
Windsor
The Asgard may not be a good match for IEMs. It does have a fair bit of internal noise.
