cdacosta
For your portable gear the cable is trickier. You would have to be very good at soldering or use adapters to attach to a signal input or output. Because it looks like all of your input and outputs are 3.5mm jacks. Doable, just have to be able to a good job soldering. I have not yet tried filtering SE headphone powered output.Thank you.
You make a compelling argument to at least try it but I am lost to know where to even start since it seems to be so much more art than science, at least a science that can be quantified.
It is more art than science. But that does not matter, what matters is "will such a device improve the performance of a portable device"? I am thinking it will. Just get a large bag of Magnetite, and figure out what open signal inputs or outputs you have?
Ok assuming you do not have unused input or outputs that have an RCA jack, 1) How are your soldering skills? and 2) what unused input or outputs are on your 2 devices?
