Runrunsmithfly
Previously known as ssmith3046
I think you're correct. I hope that they can keep it $400 or under.I think the next Modi or Modius Multibit will use TI chips, but the price will definitely go up...
I paid $1500 for my Focal Clear Pros a few years ago and $300 for my Sennheiser HD600 headphones and enjoy the HD600's just as much. Each one brings something different to the table. $3000 is out of retired income budget.Andrew Park on « the Headphone Show » YouTube channel said the same thing. He is a real headphones expert, and the amp / DAC part he doesn’t really worry about too much. The problem is at the level of interest he is at, great headphones, the prices start at around 1500 Dollars. The story starts there, 1500 Dollars. But to really be in it is around 3000 Dollars.
Whatever it is it'll never beat the Schiit SchtainAs soon as they introduce the Schitt Pantzer, I'm buying it, whatever it is!!!
Ha!!!Whatever it is it'll never beat the Schiit Schtain
I'd settle for a Schiit Pi case that I could put a raspberry pi in. One that matches the Magni/Modi form factor.I'm waiting for the Schiit Pi network streamer.
Congrats, the Asgard3 remains excellent for it's price as an 'entry level' amp.I just received my new Asgard 3 with ESS DAC module. I bought it for desktop convenience over my battery powered DAC/Amps.
I am using my Fiio M11 Plus as the source through a ddhifi USB C to C cable. It sound’s excellent with Aeon Noire, DT1770 and HD600 using the ESS module.
Plenty of power, without A/B comparing it seems similar in power output in high gain to ifi Diablo in Standard gain, perhaps Turbo. I actually thought it might be immediately more powerful than Diablo but on paper they are pretty similar I guess.
What surprised me was the total lack of noise floor on low gain with IEM and how big a difference there is between low and high gain.
Anybody concerned with the voltage output of the ESS module need not worry. I plugged in a Chord Mojo as the DAC and at its 3 volt line out it was marginally louder but at 4 clicks down to nearer 2 volts the volume was as best I could tell the same as the ESS module.
Only an hour in but very happy so far.
Ignore the $$$, the Asgard 3 is NOT a starter amp.Congrats, the Asgard3 remains excellent for it's price as an 'entry level' amp.
Totally agree with you on IEMs, the A3 is fantastic with all of mine, including the notoriously finicky Andromeda. What are you using with yours?
Jotunheim 2 and Lyr+ are two options from the Schiit line. Jotunheim 2 offers a balanced output and Lyr+ offers the option to use tubes. And they both sound different then the Asgard 3 - however, I only have the Lyr 3 and haven't properly listened to the Lyr+ yet.What amps would you consider an upgrade from the Asgard 3?
I have a Asgard 3 and Modius AKM version, which is a great combo. The upgrade I made was to Jotunheim 2 and balanced throughout the chain.What amps would you consider an upgrade from the Asgard 3?
I have a V280 next to my Asgard 3 and it betters it in all aspects.What amps would you consider an upgrade from the Asgard 3?
