Josz27
- Jan 18, 2016
from specs I could find, HE6se is 83.5 dB, 50 ohms, A3 is rated for 2.5Wpc max into 50 ohm loads, so that should work just fine for typical listening (1.4W should reach 115dB, about twice as loud as a smoke detector), unless you are an extreme base-head. My A3 is driving a set of ~92db planars, and volume control between 8:00 and 10:00 max in high gain with a 2V DAC as source.Any idea on if an Asgard 3 has enough power to power the HE6se?
Lyr3 also has 4W into 50 ohms, straight from SE (no balanced)Otherwise Jotunheim 2 is 4Wpc into 50 ohms, but you will need a balanced HP cable as well. Magnius is 3.2W balanced into 50 ohms, but practically speaking, 3.2W of Magnius and 2.5W from A3 are about the same max volume level, with A3 actually having a bigger PSU and better warranty.
This definitely is not normal, does it make any difference turning the amp off/on, restarting the computer and/or unplugging/replugging the usb (and also try another USB port)?I started noticing some slight distortion in the left channel when using the DAC. After that both channels became extremely soft and highly distorted. This is when using the USB DAC input. It is unusable now. The amp itself is fine when using the analog audio input.
Anyone experienced this issue?
Not their usual MO, I have always gotten a reply within a day - but I haven’t emailed them after covid struck and that always complicates matters. Wait a few days and try again I’d say (and double check the spam folder if you have one).I’ve sent 3 messages and email to Schiit tech support, but have not gotten any response
To beyond healthy levels.Any idea on if an Asgard 3 has enough power to power the HE6se?
Thanks for your suggestions! Yes, I’ve tried power cycling the amp, tried different computers, iOS devices, USB cables, etc. All the same result.This definitely is not normal, does it make any difference turning the amp off/on, restarting the computer and/or unplugging/replugging the usb (and also try another USB port)?
My tip would be to sit back, relax and enjoy it!Hello all,
Joined the Schitt family as of yesterday. Got the Asgard 3 with no module + Modius. Very excited to receive these in 6-8 weeks…
Pairing this with the Denon AH-D9200 and Senny 598SE!
Any tips I should know of?
+1 to that. Think of the Asgard 3 as the gateway drug to this hobby, so welcome! It's a lot of fun.My tip would be to sit back, relax and enjoy it!
Alternatively, get ready to buy a whole lot more IEMs and headphones.
Absolutely this, it’s remiss of me not to have commented sooner.Low gain and low impedance allows for IEMs.
Probably super late but - any updates on how this setup ended up being like? I had the unfortunate experience of using an HD598SE on my Asgard 3 which immediately went up in smoke...Hello all,
