Is it possible to use a iphone-CCA-usb directly into the daccard in asgard? or must it be a PC etc?
Schiit Asgard 3 - Impressions Thread
- Thread starter XERO1
While waiting others to reply, for proper solution..Is it possible to use a iphone-CCA-usb directly into the daccard in asgard? or must it be a PC etc?
My Suggestion actually you can try for iPhone DAC dongle, with Mini to RCA cable.. that's is a simple solution, SQ wise, you need to try & found out yourself if it suits you..
I know for sure it works with Bifrost2 (iPhone11->LightningToUSB->USB A-B cable->Bifrost2) without issue.Is it possible to use a iphone-CCA-usb directly into the daccard in asgard? or must it be a PC etc?
IIRC it also works with the internal multibit DAC card. I don’t know about the internal D/S DAC card, but I believe it should work with that as well.
What might happen is that the iPhone detects too high a power draw from the connected device (the USB transceiver in the DAC). If so it should work by connecting through a powered USB hub.
Chastity
- Aug 24, 2002
I have a USB-C to USB-A passive 4-port hub that I use to do phone to DAC.
The staging increase...
Mightygrey
It works with Android devices, so I imagine that it probably will.Is it possible to use a iphone-CCA-usb directly into the daccard in asgard? or must it be a PC etc?
Been a while since I give impression, here we go
with parameter as following,
Cans I used is IEM CFA SOLARIS classic
Source to compare :
Config A :
- Laptop using Audirvana (upscaling 2x or 4x), & flac song (PCM max to 192 khz)
- DAC / AMP : ASGARD 3 with MultiBit (DAC build in). low gain
Impression : No hiss... amazed... Tonality a bit or tends to bright for my taste. Intimate staging presentation, Flat soundstage.
Good & detail subbass, Slam mid bass, a bit recess male vocal still detail, very clear female vocal, a bit extend Presence, quite edgy spark brilliance... in term of separation, I find this config is better then the other one.
The Multibit DAC reminds me or R2R DAC, in term of grainy sound, IMO.. but I dont have R2R DAC equipment with me now. so based on memory.
Config B :
- Laptop using Audirvana (upscaling 2x or 4x), & flac song (PCM up to 768 kHz)
- DAC : E30 with LPS P50.
- AMP : ASGARD 3 (AMP only, RCA). low gain
My impression : Louder sound, assuming I get the volume pot on the same level & no HISS...
Tonality wise, seem more Neutral then config A. with puncier mid Bass, & decent subBass. I find the Vocal / Mid more less the same. The High, I find the Brilliance is a bit smoother (Solaris seems less sparks).
Technicality wise, This config give better depth soundtage (but same in Weight and height).
After the test, I get more impression on the DAC difference. I will update this again, when My A50s arrived, just to get a bit benchmark more on the AMP side.
And if we talk only about DAC/AMP ASGARD 3 Multibit, somehow I find (& told before), you will get 3 (or more) difference tonality, with just changing from lo to hi gain, IMO..
I did experience this at the beginning. and I prefer the lo gain, where the music seems more laid back, and relax...
Supposed to be with Headphone.. but I just want to highlight that, with the noissy IEM, ASGARD 3 can execute very well, even better then DAP... that I can say (even compare with my DX300, a slight hiss is still noticeable ).
edit : Pre heat is required for DAC MultiBit, around 5 - 30 minutes... if not pre heat, the sound sig will be cold and clinical... IMO...
Source to compare :
Config A :
Config B :
Josz27
- Jan 18, 2016
Does anyone here have used any ART or AD Audio technica headphones with A3? How is the pairing?
Mightygrey
The ATH-ADX5000 and ATH-WP900 are both awesome pairings with the A3 from my experience.Does anyone here have used any ART or AD Audio technica headphones with A3? How is the pairing?
Josz27
- Jan 18, 2016
Anyone knows why Asgard 3 ships in 6-8 weeks? Will there be a date in where it ships faster?
What a shame that I have to pay like 60 usd shipping +60 usd import taxes and it takes too long to ship
My guess - supply chain issues. Lead times for raw materials and manufactured components across almost all industries are ridiculously long at the moment.Anyone knows why Asgard 3 ships in 6-8 weeks? Will there be a date in where it ships faster?
I'd keep an eye on the classifieds / second hand market if you're wanting to pick one up in the near future but unsure where you're located so shipping may still be an issue.
airwhale
Not knowing where you are, but there is a retail operation in Europe: https://www.schiit-europe.com/What a shame that I have to pay like 60 usd shipping +60 usd import taxes and it takes too long to ship
No extra import tax if you live in the EU, but of course, the VAT applies. Shipping should be much cheaper than USD 60/- too.
davidfrance
Maybe one day Schiit Europe will have products again, but the last year, more or less, they have had next to nothing. They sold a few Modi 3+ and Magni (?) in April (?).
davidfrance
I bought one in April. An Asgard 3 with a Multibit card, 230 V ... It shipped in 3 hours.Anyone knows why Asgard 3 ships in 6-8 weeks? Will there be a date in where it ships faster?
The answer to your question would depend on a dozen or so components. Any one of them, a problem, the entire unit is not ready.
Josz27
- Jan 18, 2016
The page itself sayd that the card A3 ships like in 3 days, but the non cards ones in 3-6 weeksI bought one in April. An Asgard 3 with a Multibit card, 230 V ... It shipped in 3 hours.
