Asahi Templar
I have been thinking about getting a pair of RT open cans a year now because of the price, look, and portability, and because of the genre, I listen to, classics and jazz. I am not rich enough to consider Aeon flow Gen 2, so I am curious how the RT version comparest to the much more expensive flows 2.
I have some Aeon Open RTs on the way and owned the Aeon Open 2 last year so I will try to compare them as best I can with the caveat that it will be the memory (and the EQ profile) of the Aeon 2 I am comparing to!
Glad the Aeon got a positive review! Personally I am happy the Aeons have less upper mids that harmon as I find harmon to be quite shouty. I think its good to ballpark Harmon curve but there is definitely room for improvement with it and I think its better for headphone creators to give their own take on a target curve personally. Its good to be close enough that you can EQ it easily if you want it, but should never be seen as failing if it doesnt perfectly match it IMO.
