My 16ohm came with 2 layers of pink cloth, that look similar in texture to the yellow ones.Not sure if that has changed but my 16ohm version didn't come with that yellow layer.
SASH Deux & Tres; impressive planars from Ukraine
- Thread starter Roderick
arielext
Yeah I got a small glued-on pink square to guard the driver and cable.My 16ohm came with 2 layers of pink cloth, that look similar in texture to the yellow ones.
b0lt 0ns
anyone used these on tubes? i tried them on my WA6SE last night and they did not sound good. the bass was distorted and uncontrolled sounding. the complete opposite of my Monolith 887. im not sure why that would be.
That`s weird. They thrive on my Bottlehead S.E.X., which also is a class A SET amp. I did however do a small resistor mod to lower the noise floor of the amp, so it`s dead silent with my Tres and LCD-3F. And of course you used to low impedance headphone out?anyone used these on tubes? i tried them on my WA6SE last night and they did not sound good. the bass was distorted and uncontrolled sounding. the complete opposite of my Monolith 887. im not sure why that would be.
Working great with both my Little Dot MkVI+(full balanced OCL tube amp) and iFi Pro iCan in tube mode (tube hybrid with SS output stage).
The things that will matter with amp choice here is the ability to produce high current into low impedance. Some tube amps will struggle with either having low current output (=problems with all planars) or impedance mismatch caused by high output impedance (=problems with low impedance planars).
b0lt 0ns
yes sir i tried the high also for poops and it was worse. my Elex sound great on the low out and my senns sound great on the high out so its not the amplifier. it is a bit noisy when nothing is playing, it sounds exactly like my crack did before i did the diode mod on the ground lug however im sure thats not relevant to this issue as it didnt make a SQ difference before the mod.That`s weird. They thrive on my Bottlehead S.E.X., which also is a class A SET amp. I did however do a small resistor mod to lower the noise floor of the amp, so it`s dead silent with my Tres and LCD-3F. And of course you used to low impedance headphone out?
b0lt 0ns
i dont have any other planars to see if its a planar only issue. all my other cans are dynamics and sound perfectly fine on it. im ABing with my solid state and its night and day the difference. i also tried some other driver tubes and it made no difference. i can make it sound a little better by turning down the input volume from my dac but i run out of volume knob on the amp to get them loud enough anyways.Working great with both my Little Dot MkVI+(full balanced OCL tube amp) and iFi Pro iCan in tube mode (tube hybrid with SS output stage).
Do you have a bad tube or tubes? That’s the first thing that comes to mind with that sort of behavior. Do you have some other known good tubes to test with?i dont have any other planars to see if its a planar only issue. all my other cans are dynamics and sound perfectly fine on it. im ABing with my solid state and its night and day the difference. i also tried some other driver tubes and it made no difference. i can make it sound a little better by turning down the input volume from my dac but i run out of volume knob on the amp to get them loud enough anyways.
b0lt 0ns
yes i have changed tubes. im listening to my Elex on it, same everything, sounds perfect.Do you have a bad tube or tubes? That’s the first thing that comes to mind with that sort of behavior. Do you have some other known good tubes to test with?
How about the cable you’re using? Have you tried a different cable? Does the Tres sound fine on other amps?yes i have changed tubes. im listening to my Elex on it, same everything, sounds perfect.
b0lt 0ns
half of the same cable as im using on all my other headphones (hart modular) and yes i can disconnect it while playing the same track and connect to my SS amp and it sounds perfect. same DAC same PC. it makes zero sense.How about the cable you’re using? Have you tried a different cable? Does the Tres sound fine on other amps?
- Mar 20, 2013
If I may ask, which one do you fancy more? And if that's the case, are there any particular reasons why?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I already took out one of the yellow felt sheets from my open back drivers, I will try with both removed (leaving the third glued one of course) but do you guys think there's any risk to the headphones without at least one of those sheets of felt in place to help protect the driver and wiring from dust or anything? I'm thinking no since the open-back covers also have a filter as well.
HardstyleLoco96
- Jan 21, 2014
No the driver should be all goods. Give it a try and see how you like itI already took out one of the yellow felt sheets from my open back drivers, I will try with both removed (leaving the third glued one of course) but do you guys think there's any risk to the headphones without at least one of those sheets of felt in place to help protect the driver and wiring from dust or anything? I'm thinking no since the open-back covers also have a filter as well.
Must be an incompatibility with your amp. I would talk to Sasha and see what he thinks.half of the same cable as im using on all my other headphones (hart modular) and yes i can disconnect it while playing the same track and connect to my SS amp and it sounds perfect. same DAC same PC. it makes zero sense.
