SAmsung galaxy note 2
Mar 29, 2013 at 12:40 AM Post #361 of 471
sadly even with the display settings set to maximum (adjust tone and auto off) i measure the brightness at just 250 cdm compared to my walkman z at 350 cdm. No chance of using in direct sunlight then.
I was using mine (international version) on direct aussie sunlight just fine though, I am using he max brightness , kinda better than IOS screen
Mar 29, 2013 at 4:59 AM Post #362 of 471
well admitedly i havent tried it yet, i am in the UK and we get about 2 days sun a year
but i couldnt use the walkman in direct sunlight and my note is less bright than the walkman.
Apr 3, 2013 at 8:40 AM Post #367 of 471
Anyone with comments on the HP out for the Note 2 and comparisons to other things like the iPhone's etc?
Apr 3, 2013 at 8:08 PM Post #369 of 471
Do you mean the sq? I like note 2 better compared to the iphone 4s, and its pretty comparable to the likes of j3 or the n1, totally losses out to my new ak100 though
Yup meant the Sq. Thanks. AK100 should definitely be better!
Apr 4, 2013 at 4:52 AM Post #374 of 471
but once you add a portable amp/dac the note wins again! hows the camera on the ak100?
Might be better off going with a dedicated source in that case I reckon.
Apr 4, 2013 at 9:05 AM Post #375 of 471
http://ko.goldenears.net/board/index.php?mid=GR_Mobile&document_srl=3037355
Some objective assessement...from the good folks of Goldenears.net
It does great the most important thing (output impedance) and acceptable in the rest of areas. Overall i think that it's a good pair for balanced armature iems.
