Same problem with the note 2. Last anti glare I had didn't exactly help a great deal either. The note 2s screen is not as bright as an iPhone on my recollection.
The N2's screen can match or even edge past the iphone's retina display. You would have to change some settings of course. You can kind of compare the displays on Samsung's mobile phones to their HDTV's, in a menu feature sorta way lol. Just like in the bigger brother displays, you can also find picture quality mode settings in the N2 and S3. They are (as they have always been on the tv's) Dynamic, Standard, Natural(this one's a new addition), and good ol' Movie modes.
To get there you go to Settings > DIsplay > Screen Mode > then select either of the 4, but to match iphones color depth and brightness, select either Natural or Movie Mode.
After that hit the save button on the upper right corner then it will bring you back to the Display settings, and from there, scroll down to: 'Auto adjust screen tone' all the way on the bottom and uncheck that setting.
Now scroll back up to crank your brightness all the way max, and baam! you now have a screen that you can see in direct sunlight.
Note: These instructions are based off the stock Note 2 rom. Custom roms still has these settings, but might be shuffled around differently.
Hope this little tip helps!
