theaudiohobby
- Aug 12, 2003
Principles of Sigma-Delta Modulation for Analog-to-Digital Converters Sangil Park, Ph. D., Strategic Applications, Digital Signal Processor Operation ...Sometimes, the S-D modulator is referred to as an interpolative coder. The quantization noise characteristic (noise performance) of such a coder is frequency dependent in contrast to delta modulation. ... this noise-shaping property is well suited to signal processing applications such as digital audio and communication. Like delta modulators, the S-D modulators use a simple coarse quantizer (comparator). However, unlike delta modulators, these systems encode the integral of the signal itself and thus their performance is insensitive to the rate of change of the signal. |
Originally posted by JaZZ As far as I'm concerned, the corresponding resolution values for 20 kHz and the different formats are as follows: CD..............16 bit DVD(-A).......24 bit (up to) SACD...........7.17 bit (equivalent) 2,822,400 : 20,000 = 141.12 = 2^7.17 [corrected: 241.12 --> 141.12] [/B] |
Originally posted by theaudiohobby Correct me, if I am wrong, LPCM is a series of absolute n-bit words with the largest n-bit word being at the Nyquist cutoff frequency and the smallest n-bit word at DC (that is 0Hz) for a given sampling frequency. |
Therefore in LPCM, the size of a given n-bit word is proportional to the sample point position wrt to the sample frequency. In other words, these are absolute values and the issue of steps as you portray it does not really come into play at all. And the bit-depth is constant over the entire bandwidth in line with this principle. |
On the hand, DSD being SDM is a series of adjacent n-bit words with each successive n-bit word encoding the relative amplitude difference between successive adjacent sample points. Therefore in this case, each sample point corresponds to a single bit, so you have 141 'adjacent' bits to capture a signal at 20KHz. Your calculations do not seem to take into account that these are 'adjacent' 1-bit words as opposed to a single absolute n-bit word as your text seems to assume. In other words, summing the bits in the manner that you have done does not really work. |
Originally posted by JaZZ Frequency is not encoded in the samples, just amplitude values. So each sample has the same word length: 24 bit. The «largest» word in terms of value is the one which indicates maximum amplitude. Frequency is the result of the shape of the curve resulting from the sample values. |
Yes, the bit-depth is constant with (L)PCM. (Why «L» in this context? Is there any nonlinear PCM in play we have to exclude?) But I don't understand the reference to the sample frequency. And the steps are a digital-inherent phenomenon anyway. In graphics you have a bit depth of 8 bit per color channel (at 24 bit), that means you have 256 brightness values (= steps) at your disposal. Correspondingly in high-rez PCM with its 24-bit word length you have 16,777,216 amplitude values/steps at your disposal. |
In fact DSD doesn't use word lengths expressed in bit, there are no such codes [/B] |
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Originally posted by theaudiohobby Yes, However the same word represents a different amplitude at different sample rates. |
...the amplitude is a function of the frequency of the signal wrt to time. |
Actually, you do not have 16,777,216 amplitude values/steps at your disposal... |
...what are you trying to say here exactly when you say "DSD doesn't use word lengths expressed in bit..." |
As mentioned previously in LPCM @192KHz, a 20KHz signal will have only nine sample points and only a maximum of nine of the possible 16,777,216? values (n-bit words) will be valid amplitude values for this signal with only one amplitude value/step being valid at each respective sample point. |
originally posted by Joe Bloggs Oh yes there is. 0 65535 0 -65535 0... This is a pure tone at 48kHz! *for 192kHz sample rate. It could also be a 12kHz tone for 48kHz sample rate, etc. |
0 65535 0 -65535 0... This is a pure tone at 48kHz! *for 192kHz sample rate. |
Originally posted by JaZZ First let me ask about the intention behind the quotation of Joe's example. |
Originally posted by theaudiohobby ...in LPCM a fixed n-bit word corresponds to a different amplitude for different sampling frequencies i.e. the n-bit word will correspond to a different amplitude for each change in sampling frequency. |
