Originally posted by theaudiohobby
Rubbish..we just spent a couple of pages of this thread discussing time-domain performance that is amplitude vs time which is the impulse response. He should read up on some of the links and previous pages on the thread. As I said, if he disagrees with my assertion, he should provide some concrete evidence to that effect. |
theaudiohobby, let me reiterate what Jazz is saying here:
A sine wave at 20kHz has a period of 0.00005s. It goes from the top peak to the bottom peak in half a period, 0.000025s.
The space between two sampling points in SACD is 1/2.82MHz = 3.54308....e-7 s.
There is thus only
71 sample points covering the time between this top peak and bottom peak. (rounded
up to the nearest integer. I'm being generous here)
If we want SACD to be able to encode a full-scale signal at 20kHz, that means 71 down bits should take us from the highest voltage signal to the lowest.
Which would mean that there are only 71 possible steps an SACD waveform can take--compared to 65536 steps in CD and 16,777,216 steps for 24-bit DVD!
Or if we want SACD to go up to 22050kHz full scale
CD is 16 bits and DVD is 24bits. By this analysis SACD would only be the equivalent of 6.15 bits!
(my numbers differ from Jazz because of two things: firstly, he made a typo: 2^7.17 is
141.12, not 241,12
secondly, he forgot that a sine wave goes from peak to peak
twice, not just once, so the number of samples between two peaks should be half of the number he calculated.
Note that this is not in contradiction to the impulses we were looking at earlier: for example if you want SACD to have a rise time from bottom to top of 6.122us=0.000006122s (as shown earlier), you just need to reduce the number of steps between top and bottom to 6.122us / 3.54308e-7s(space between two samples) =
18 samples =
4.2bits! (again, rounding up
Now, there is something fundamentally flawed about the analysis above, but seeing as you deem yourself to have such a superior understanding of the ins and outs of SACD, I leave it as an exercise to you: oh, pray tell, what is wrong with this conclusion?? I challenge you to explain this yourself instead of referring us to some paper you don't understand
