- Aug 18, 2007
Webbie,
Much of the time, my Predator is being fed by my iMod, and then second most common is using the Predator with my Micro DAC with iRiver H140 or Macbook using optical output. However, the Amp section is so good that I still like the Predator driven by the DAC more than my Pico, which does have a superior DAC with better sound-staging and transparency but works better as source to me than as an amp (like you use your D1).
So yeah, I use the Predator with iMod and Micro DAC optical, which are superior sources to ANY of my USB DAC, but I can't say the Predator DAC is disappointing at all when compared to superior sources feeding the Predator amp. Yes, the DAC is not quite as good the one in the Pico, Micro DAC, D1 or D2, but for me it is close enough that if I use the Predator with it's DAC I still enjoy it very much, and the amp section is to die for.
So, I partially agree with you that there are better DAC Amps out there, but I disagree with how bad you say it sounds via DAC. I know you said "quite listenable", but "big disappointment" came right after that. I would say it is a little less open and detailed, missing a little of the ambience and micro-details of the D1, Micro DAC or Pico, but I wouldn't go as far as disappointed.
Also, to my ears the Predator, Pico and Micro DAC have more bass than the D1 DAC with 6234, 6241 or 8656 opamps. I was having to use AD797 opamps in the main amp, and use the headphone out as a DAC pre-amp out to get the right amount of bass.
