S Crowther
Any other changes in roon 2? Any changes in SQ?
Yeah to my ears, native Tidal app sounds better than Tidal thru ARC, which sounds compressed/thin.Also if you are using Tidal or Qobuz, isn't this running it twice. First you have to access ARC to request track selection, Roon Core has to go out and pull in that track from the internet and then sent it back to ARC to be listened to. I would rather just use the Tidal / Qobuz app directly.
I don't see this enticing anyone to now buy Roon for $10 per month. Am I missing something?
I don't understand, why can't you also update your Roon remote app on your PC? What O/S are you running?Well, I'm EFFING PSSD about 2.0.
Upgrade to 2.0, it said.
No prominent warnings or ReadMe about why you might not want to.
So I did.
And after Roon Core was upgraded to 2.0 was when I discovered that my normal PC-based Roon remote app is incompatible and not upgradeable.
Roon Core doesn't want to migrate back. (It's supposed to be able to.)
I do NOT like navigating around Roon on a tiny 3x6" screen. Totally ruins the experience.
Did I mention I'm PSSD? Yeah, I'm PSSD.
[/rant]
For me, the biggest thing is being able to listen to the playlists I have created in Roon on the go. They have a mix of Tidal, Qobuz, and local music - so it wasn't easy for me to recreate outside of the house. I think this was their most requested feature, so there's a lot of happy Roon users.I don't see the point of it. When I am out I have my DAP which has all the same albums that are in my computer in the house.
Not sure if you saw this:Well, I'm EFFING PSSD about 2.0.
So I did.
[/rant]
