Roon is live
Jan 1, 2024 at 3:28 PM Post #691 of 737
It had windows on it. It wasn't rock. And at least once a week sometimes more it would kick out of roon
Ah that explains it, because ROCK is stable and reliable. However it does take some tech savviness to install ROCK. There are slight differences between NUC models (e.g. BIOS setup) and requires some understanding of what's going on when Roon's installation instructions don't exactly line up with what you see.
Jan 1, 2024 at 7:46 PM Post #692 of 737
Jan 1, 2024 at 7:59 PM Post #693 of 737
Jan 1, 2024 at 8:53 PM Post #694 of 737
Jan 1, 2024 at 10:24 PM Post #695 of 737
As someone who set up a NAS with Roon server, the ROCK setup isn't easy. I dabbled in ROCK territory a bit. If I had the money to spend on a pre-built solution, I'd take the Nucleus without hesitation.
Well, as someone who has been building/re-building computers since the '90s (in my spare time for friends and family, Mechanical Engineer by profession...), Rock is pretty dead simple, even building a NUC from scratch is not hard at all. To each their own experience, though). :ksc75smile:
I feel Nucleus is overpriced for what you get, only my opinion, FWIW, but others might think it's worth it to not deal with building their own... :beerchug:
Jan 1, 2024 at 10:32 PM Post #696 of 737
So, in other words, you're very confident in building computers. Most of us sre not. I've built computers over the years, but gave up long ago.
The NAS was truly simple. The Roon app is native to the QNAP. One simple download.
Jan 3, 2024 at 1:06 AM Post #697 of 737
Since i use Roon virtualized i had it running as VM with the ROCK image on Proxmox.
But now i settled with an LXC running Roon Server, which uses less ressources then the VM and still can automatically update Roon itself.
No drop out, no hassle, while running HQPlayer Embedded on the same host as VM (LXC is not possible because of the kernel).
Jan 9, 2024 at 9:14 AM Post #698 of 737
Roon Nucleus Titan is coming soon. Priced at 3,699 USD with interchangeable top plate.
Source: https://x.com/ecoustics/status/1744518313978540178?s=20
Jan 9, 2024 at 12:21 PM Post #699 of 737
Apr 22, 2024 at 9:22 AM Post #701 of 737
Apparently there is also the Roon Nucleus One for 500$ coming in June...I wonder what the differences (apart the heavy casing...) are between both ?
It's overpriced by about 300 bucks. it's a low powered celeron equivalent and faster systems that would work better can be had on amazon for around 200,.
Jun 3, 2024 at 6:06 PM Post #702 of 737
I've been using a mac mini m1 as my roon core, but recently ran into a problem with MacOS + DMP-Z1 compatibility issues in exclusive mode. I was thinking about swapping to a Roon Nucleus or possibly building a NUC, but wanted to hear some feedback on how well it works. I love the mac mini because it is so quiet from the apple silicon and I can run HQP on it too.
Jun 4, 2024 at 3:02 PM Post #704 of 737
Second the more inexpensive Roon box. Unless you have an insanely large file collecton, the more expensive options likely a waste.
TBH, it sounds like you need a Roon endpoint for the DMP-Z1. Why not look at something like the SoTM Neo 200? IIRC Roon advised against running USB DAC from Nucleus, so that likely will not suit your needs.
Jun 9, 2024 at 3:09 PM Post #705 of 737
+1 - I use the SoTM sMs-200 Neo ultra together with a Nucleus. They work like a charm. But I guess the SoTM would be great too with the MacMini....
