Romi Audio - The official thread
Sep 25, 2021 at 4:23 PM Post #766 of 928
I listened to this combination yesterday down at the waterfront. Used my Android streaming Amazon HD as a source. I've come to the conclusion that this is likely the equal of my home stereo setup that cost roughly 15K or so. Love this amp!
I think it could be even better if I upgraded the cable between the dac and amp. Right now using an Amazon special that cost about 25 bucks. Anyone recommend a reasonably priced upgrade cable?
Happy to see another xDuoo X10T II-Dunu Zen user here. Great setup! My BX2+ is gone, but I have very fond/recent memories from it.
Oct 5, 2021 at 3:49 PM Post #767 of 928
Any specific requirements for a power bank to simultaneously power and charge the BX2?
Oct 8, 2021 at 3:58 AM Post #768 of 928
Any idea about what should be theoretically the best line in voltage input in balanced mode ? I can choose with the A&K Kann Alpha balanced line out set to 1.6V, 2V, 2.5V or 4V ?
I don't ear any background hiss at any input voltage and high or low gain mode.
I would say from 2V, it sounds powerful enough to move a DCA Stealth with the BX2+ (High Gain).. but difficult to say if at 4V as line in with BX2+ in low gain mode, there should be some improvement with Class A mode.... or even if I should have a better battery life.
Oct 8, 2021 at 3:55 PM Post #769 of 928
I'm far from the expert but as I understand it 4V is basically the standard for balanced connections. If you can run that way and then keep the amp on low gain to increase battery life it seems like a win-win. Battery life is the only disappointment I have with the Romi but I'm willing to accept it for the great sound. The way I listen the battery actually lasts long enough but that's probably not the case for everybody
Oct 8, 2021 at 4:34 PM Post #770 of 928
I think some other amps recommend 2.1V even for balanced input.
As I couldn't find any info specific to the Less Bx2+, I was wondering if SQ could be affected by using 4V and low gain.
I don't know with the Bx2+ but for other amps in low gain, less amp's modules are activated so instant juice can be really restricted too when needed.
I am using it at 4V low, I didn't find any real improvement for battery life (I just know that I get 3 hours or even less in 2V input and high gain).
Oct 9, 2021 at 11:38 AM Post #771 of 928
These are my observations of high gain versus low gain using the Dunu Zen with the BX-2 plus. I do find the high gain to sound more energetic but there is an audible hiss. It only seems noticeable when nothing is playing. I've been using low gain because of this, but I think I'm going to give high gain another chance based on what I have read here
Oct 11, 2021 at 11:56 AM Post #772 of 928
I have a BX2 (non plus), that will now only work connected to power. Are replacement batteries easy enough to drop in?
Oct 11, 2021 at 12:59 PM Post #773 of 928
I seem to remember a photo that showed one opened up and it looked like a standard battery that was just a simple unplug. I'm not 100% positive however. I would send an email to Romi. They've always been good about getting back to me whenever I had a question. Eventually we'll probably all have to figure out how this works. Although my Chord Mojo is several years old and the battery still seems as good as new. Just thought of something, did this happen all at once or gradually? If all at once maybe the battery isn't bad, maybe some kind of a connection has failed inside. When plugged in to charge, what is happening with the green and red lights on the side? Have you tried a different charger and cable? I've seen several chargers and cables go bad. Good luck, let us know what you find out
Oct 11, 2021 at 2:30 PM Post #775 of 928
They should have put a knurl on the pot
I’ve acquired it recently and despite it having seen low usage by a couple of previous owners, I think it’s been sat idle for long periods at a time. I’m not convinced that isn’t perhaps an issue with the charging indicator being wrong. As it currently stands, I can run it connected to power, with all bar one LED lit. If I remove the power, the blue LED around the volume wheel goes off and the sound it puts out sounds like you’d expect it to if it were on its last ounce of juice! I’ll try do some full charge/discharges to see if I can coax a bit of health into the batteries.
Nov 10, 2021 at 3:34 PM Post #776 of 928
Nov 19, 2021 at 1:22 AM Post #778 of 928
Interesting..looks like can be external powered and have 3 gain level now
Nov 19, 2021 at 2:23 AM Post #779 of 928
:sob::sob::sob: why such awful color ???
I wouldn't go out and use it in trains or planes with this bling bling color.
Now, I really hope the Fiio M17 will be sufficient to power my low sensitivity headphones on the way (DCA Stealth)
Nov 19, 2021 at 2:31 AM Post #780 of 928
Agreed. Wow, bling bling, indeed. Matt black would have been more pro in my estimation. Still, glad they fixed the typo.
I don't think there's any portable solution for the Stealth personally.
