vicnsi
- Oct 23, 2016
You didn't void your warranty by installing Rockbox because the person who ported it to the X3 provides a separate file which is the original bootloader that you can re-install on your player which returns it, after you also delete the .rockbox folder, to the factory state (actually you don't have to delete the .rockbox folder since it's on the memory card and if you return your player you wouldn't return it with a card inside, but the bootloader has to be returned to its original state).
Nevertheless, before you go through the hassle and delay of returning your player, just get yourself a Torx T5 screwdriver and try disconnecting the battery.
re: "a separate file which is the original bootloader that you can re-install on your player which returns it, after you also delete the .rockbox folder ... "
The problem though, is that the player is completely dead!!! as in Flat-line dead, No-sign-of-life dead! i.e. There is NO WAY to access or re-install the original bootloader on the player which returns it [to factory state].
FWIW, This morning I tried again to connect the X3 to Windows via the original supplied USB cable; it makes the typical windows sound that you hear when you connect an external/USB device. But no external connected drive icon shows up in Windows (as it was doing before the crash). i.e. it seems as if Windows is still able to detect that an external device has been connected, but it can't go any further than this to actually provide any info on what the device is, and therefore there's no way to access the contents on the device...
I'm slowly becoming convinced that what has occurred here is a total hardware failure on the Xduoo X3. Not absolutely sure what caused it though...
PS: Oh wait ! I forgot to mention that when I take the SD micro Card out of the player and pop it into the card reader on my PC, I can see/read/edit all the files, no problem at all. (I am using a Kingston 128 GB Flash Memory Card with a microSDXC to SD Adapter)
