Subdrek
- Aug 20, 2016
If you're following XVortex's instructions, it should work. Is the .rockbox folder (and its contents) in the root directory of your SD card? When the X3 restarts after you press the Reset button, does it boot into the original firmware? Will it boot into the original firmware if you keep the Hold switch on while you power on?
After I reset, it boots to the original firmware. It will not boot to the original firmware until after I restart it. When I update, I never get an indication that rockbox is installing; it just turns black and essentially bricks until I hit restart.
.rockbox is indeed in my root.
Before I restart it, after i choose to upgrade, I cannot boot my original firmware no matter what.
