I have a plans to release a rockbox for x3ii by the end of summer.
I don’t think it will run Rockbox.
XVortex so far has done everything he said he would. I would encourage everyone to donate heavily on XVortex's main page.
What do i do if i want to install X3-VTX5.zipEnabled equalizer (edit file mplayer.conf and put it to the root of TF card) and optimized (stripped) binaries for speed and size.
Let's not get carried away... Rockbox.org has not provide an image that can be used directly on X3; XVortex has adapted the raw Rockbox image for use with X3... The logic implies that it is up to XVortex to redistribute a share of the donations (that may have come his way) to Rockbox.org.I would also like to add that Rockbox also has a donation page (https://www.rockbox.org/), without their firmware and they also make it open-source, then this X3 Rockbox port would not have happened.
Tricky, isn' it...?
Tricky, isn' it...?
Hi all.
I've got Rockbox on my X3, and I keep it in a soft pouch cable bag in my rucksack.
My problem is that frequently I find that the buttons have been pressed in transit, turning the x3 on and running the battery down.
Because the lock switch has been re-purposed by Rockbox, is there another way to lock the X3 to prevent this happening ?
I have searched this thread but couldn't find anything related to this.
Pete
The only issue I'm having is that it is not being recognized as storage when I plug the microusb into my computer to charge.
I also get this behavior, though I'll admit I never use USB to transfer or manage music. When it DID work it was so painfully slow as to be useless. I always use a USB MicroSD adapter and just pop out the cards.
I know USB has been historically tricky on some Rockbox ports, and it's likely that XVortex doesn't have time to deal with it. For me it's far from a deal breaker.
The case I made from the $2 Nintendo DS case prevents all inadvertent button presses, regardless of the lock button position. If you search the thread, you’ll find the details/How2.
