Rockbox for iBasso DX50 dual boot with stock firmware
Nov 21, 2014 at 6:27 AM Post #1,291 of 2,020
Thanks for your quick answer, I tried to reinstall the new version after deleting all old Rockbox files and the balance still don't work. The code cleaning may delete a useful part.
The thanks isn't just for the last version but for all your work on this port.
Nov 22, 2014 at 2:34 AM Post #1,292 of 2,020
Good news, ArgelErx fixed the balance issue last night. Big thanks to him!
Here are new builds:
ArgelErx's cleanup ps4  or
ArgelErx's cleanup ps4 + my modern_ui
prerequisites: installed Firmware 1.5.0 with CWM by @DOC2008  &  dualboot-app (post #1276 )
The good thing is that the new update mechanism is not too complicated. Follow all these steps one by one:
  • extract the zip file to the internal drive of your player and overwrite all files
Theoretically you don't even need to reboot.
Nov 22, 2014 at 4:47 AM Post #1,293 of 2,020
Nice Job.
I have noticed an other bug ( I know i'm annoying
) with the new "hold" setting, I select "touchscreen only", when i touch the screen where the button read/pause is supposed to be, the song is played/paused. The "hold" button (for me the on/off button) just cut off the screen but not the touchscreen.
Nov 23, 2014 at 4:17 AM Post #1,294 of 2,020
  Nice Job.
Just to clarify this:
- DX50?
- Hold Switch Mode: Touchscreen Only?
- Hold Switch engaged (in the upper/locked position)?
- The device reacts to the touchscreen?
Which Touchscreen Mode do you use (Absolute Point/3x3 Grid)? Which Theme?
I can not reproduce this.
Can someone else please check this behaviour.
Edit
Ah, its to early here, just notice this: The Hold Switch Mode setting is meant for the physical hold switch. What you want is under Settings ->General Settings -> Display -> LCD Settings -> Sleep (After Backlight Off).
Nov 23, 2014 at 4:59 AM Post #1,295 of 2,020
Sorry, in the old version just press on/off cut off the touchscreen like the hold switch I totally forgot it my bad.
You and Cholero do a great work.
Nov 23, 2014 at 7:56 AM Post #1,296 of 2,020
No prob.
Thats one of the things that has changed: Backlight and touchscreen are now (mostly) independent. Touchscreen works even with backlight off. How long can be adjusted with Settings -> [...] -> Sleep (After Backlight Off).
Nov 24, 2014 at 3:46 PM Post #1,297 of 2,020
The new firmware 1.6.0 has arrived. For those who care, here's a modded version with the bad old CWM (and theoretically adb enabled, but usually does not work in OF, in Rockbox yes!) get it: dx50_1.6.0_cwm.zip (you know: at your own risk)  edit: don't use it, see at the bottom of the post
The good news regarding rockbox is that everything still works
 (at least playback and playing around a bit are what i've tried)
To fresh up your memory how to upgrade when you have cwm:
  1. get the update.img and the stock recovery(get it from here). The update.img to the root of the external SD card
  2. flash stock recovery in cwm:
    install zip from sdcard / choose zip from external sdcard
  3. reboot to stock recovery
  4. update firmware
  5. reboot , reboot to cwm and flash the dualboot-app
    This new one is needed if you want Mango to work too:
    cwm_rb-bootloader_1_6_0_sdcard_2014-11-24.zip
    This bootloader works with the build from post #1292 (rockbox itself does not need to be updated)
If you are exclusively using rockbox, there is no need at all to upgrade the firmware. It is a minor upgrade anyway.
Edit: there is a problem with the firmware dx50_1.6.0_cwm.zip.  It will probably not work. Wait for an update!
Edit2: here's the update: post #1367
Nov 24, 2014 at 5:51 PM Post #1,298 of 2,020
  3. in cwm: install zip from sdcard / choose zip from external sdcard
  4. reboot to stock recovery
  5. update firmware
  6. reboot , reboot to cwm and flash the dualboot-app
Regarding sound, I don't think it is minor, IMO anyway. :^)
Nov 24, 2014 at 6:11 PM Post #1,299 of 2,020
  5. update firmware
If the sound is different with 1.6 will Rockbox based off of 1.6 sound different as well?
Nov 25, 2014 at 5:05 AM Post #1,301 of 2,020
  4. update firmware
You say the CWM is old and bad, what exactly does this mean for me? I'd like to dual boot with Rockbox and 1.6, but I'm not sure exactly what you mean.
Nov 27, 2014 at 5:25 PM Post #1,303 of 2,020
  4. update firmware
flash stock recovery in cwm : ok
update firmware (with update.img from dx50_1.6.0_cwm.zip) : ok
reboot to cwm and flash the dualboot-app cwm_rb-bootloader_1_6_0_sdcard_2014-11-24.zip : say aborted..... system crash !!!
reinstall stock recovery then update.img from dx50_1.5.0_cwm.zip then cwm_rb-bootloader_sdcard_2014-10-13.zip : ok
I use "ArgelErx's cleanup ps4 + my modern_ui"
