JamesG01
- Feb 12, 2013
You have to turn off the database statistics. It is a bug in the DX50 rockbox build.
Thanks, that worked
The file paths exported from MediaMonkey don't match up with file paths on DX50. Getting it right isn't hard:
- Select a directory and add everything in it to a playlist, and save the playlist.
- Connect DX50 to your host computer and look at this saved playlist file. This is what Rockbox expects.
- Edit your exported playlist file so that the paths match up.
That was an error message from the party that ported Rockbox to the DX50. Something is corrupted in your install.
If necessary (and it probably is) do a full uninstall:
- uninstall
- 1) use cwm to return to stock recovery (stock_recovery.zip from package you downloaded before)
- 2) use stock recovery to flash any update.img
Then start all over again.
Welcome to the DX50 addicted!
For me the instruction that evilhippie wrote worked great:
"1) Download the FIRMWARE_DOC2008.zip file from http://yadi.sk/d/UbPDGP_IKvVCA . Inside you will find a number of zip files, and an update.img file. Ignore the zips for now, and copy the update.img to your DX50s internal memory and install it as you would any other official firmware update. Go to settings -> advanced -> system update. The dx50 will automatically reboot into ibasso's recovery and install the modified update.img. Essentially, this update.img is exactly the same as the stock firmware, except ibasso's recovery is replaced by CWM (both of which are booted into by holding power + volume on startup). Note: Since the firmware file is about 10mb bigger than stock and contains a custom recovery, it will take a minute or so longer to finish the install. If you haven't already copied the cwm_rockbox_2013-03-25.zip to the internal memory, reboot back into the main software and do so now.
2) Boot into recovery again after the update is completed (holding down power + volume up on boot). You should see a new recovery menu with an orange eye and a top hat in the center. The bottom should read CWM-Based recovery modified by androtab.info v6.0.3.1. Now you select Install zip from sdcard, select choose zip from sd card (unlock button up and down), and select the cwm_rockbox_2013-03-25.zip (mirror at mega.nz) file. It will then ask to confirm the install. Scroll down and select yes, and CWM will install the zip. When finished, return and select reboot the system.
3) Next time you start the dx50, you will get a touchscreen with a choice of whether to launch into mango (the stock player) or rockbox. At the moment, you must launch into the stock player if you want to transfer files over usb.
4) If you want to uninstall CWM and go back to the stock recovery, simply flash the stock_recovery.zip file in CWM and the original ibasso recovery will be restored. I'm not quite sure what the other files are, but they seem to be sound tweaks which are also flashable in CWM, and one of the file contains font tweaks, possibly for rockbox."
Give it a try, step for step, it can't go wrong.
One quick question about the above instructions for installing the latest version:
Step 2 says: "Now you select Install zip from sdcard." However, Step 1 says to copy both the update.img file and the cwm_rockbox_2013-03-25.zip file to the INTERNAL memory.
Is that an error in Step 2? Should it say "Now you select Install.zip from internal memory"?
Just want to be sure before I upgrade.
I guess you're right with that. Probably you can put it on your internal memory or your sd card and use it both ways.
Hello Everyone,
only one quick update to my modded theme, I'm releasing here probably the last version of the modded rayboradio theme for Rockbox Targets 320x240.
Download: http://www.sendspace.com/file/7x8zar
changes to 7.3c1
- version 7.3c2
- Touchscreen buttons left/right have more space
- Touchscreen scrolling up/down is now repetitive if you keep pressing it
- Big cancel button in the bottom left instead of the one below the small album art
enjoy!
cholero
thanks mate.. will download it later..
is that a clock in the upper right hand corner?
Sent from my lovely Nexus 7..
oh ok..iwas thinking its a working clock lol
quick question..is it possible to replace the clock with a touch screen button that turns off the
back light?
-When I use the DX50 on the AUX connection in my Car (not the best sound system unfortunately, but usually pretty acceptable) it's clipping/distorting like crazy for like 40-50 % of my songs. For the other 50% of my songs it's perfectly fine and sounds great with huge bass impact and nice highs.
I tried both the HO and the LO and all EQ settings are turned off, bass and treble to Zero, even tried lowering the bass/treble....
Happens for Flac aswell as for Mp3.
Maybe it's fixable with lowering some frequencies in the EQ but I just couldn't find the right ones yet.Any suggestions?
- also how do I put new rockbox themes on the dx50? would love to get bigger album art.
- last but not least , there's apparently gonna be a new official firmwareupdate soon, how does the updating work then? Since it's most likely including the usb DAC functionality I wouldn't want to miss out on that
