paulybatz
- Oct 6, 2008
Contact RME...they’re quick to respond.
I don't think digital through is the mode you want . Go to chapter 17 in the manual (Modes) and set to auto , in auto the unit will select the correct mode for the connections you have . Should still work on digital through mode though so it could be the rear outputs are set too low or muted . The breakout is digital connections only the rca's are spdif out and in .Hello! Need some help again unfortunately.
Recently purchased the RME ADI-2 Pro Fs and an Ampsandsound Mogwai SE.
I'd like to connect my computer to the ADI-2 Pro Fs, and then have the unit output the signal into analog in order to plug into my Mogwai amplifier. The back of the ADI-2 Pro has two unbalanced TS outputs (left and right). Naturally I assumed that I could purchase a dual male 1/4 TS to RCA cable, connect it to the back of the ADI-2 and then RCA into the amp, set the mode to Dig Thru (Digital Through), and we'd be in business. Unfortunately it's not working, the ADI-2 doesn't let me change the source for the "Main Output 1/2" to USB; in fact, it is greyed out and indicated that the outputs can only be used in AD/DA mode.
So how do I best accomplish what I'm after? Am I missing a setting on the ADI-2?
The ADI-2 Pro Fs also included a breakout cable accessory with two female coaxial SPDIF (RCA left and right). Should I plug this into the back of the unit, then plug in RCAs to both devices? The front facing PH 3/4 seems to be the only output that works with USB, however it is front facing, and running a cable from the front of the unit then into an amp wouldn't look very good, and it just seems wrong?
Thank you for any advice you can provide!
Good call! Lean back and watch the prices rise like crazy.Hey guys, I just purchased the RME ADI 2 PRO FS R Black Edition! I am super excited and patiently awaiting its arrival.
I just use it no eqHey guys, I just purchased the RME ADI 2 PRO FS R Black Edition! I am super excited and patiently awaiting its arrival.
I am going to be pairing it with the Hifiman Arya V2 and wanted to know what advice you guys could give me? Anything would be helpful from what cables would be good, if there are any upgrades that would be beneficial, what EQ settings might be good, anything. I would really appreciate the help!
It doesn't look like the AKM chips will meet the demands much longer.
Of course the balanced adapter won't hurt. Can't claim to hear a difference myself, though. The unbalanced output seems to be very clean already.
As for settings, I'm sticking with the Slow filter and most my headphones seem to like a subtle +2dB bass boost. I really like the Loudness correction but I keep jumping between IEM and full-size that I can't find a setting that works for all my gear.
What do you use it with if you don't mind my asking?I just use it no eq
It’s amazing
You should check for reviews of the original ADI-2 Pro.I was curious as there are not many reviews for the RME ADI 2 PRO FS R, would the reviews for the RME ADI 2 DAC FS more or less apply to the PRO version? Also, if you could tell me what the differences are that would be appreciated.
Thats perfect, exactly what I was looking for, thank you.You should check for reviews of the original ADI-2 Pro.
The FS upgrade has an improved clock (FemtoSecond accuracy, hence FS) which further reduces jitter and the chip also increased the SNR by a few dB, I believe. Nothing that would change any review.
The R is for remote. That's it.
I wrote a product history rundown on the ADI-2 Pro/DAC series here: https://www.klauseulenbach.de/2019/11/24/updated-rme-adi-2-dac-november-2019/
