Is it safe to assume the aic10 shouldn't be left on overnight or 24/7 due to tubes or is there some magic in there to help the tubes life?
I usually leave low power electronics on 24/7, as it is normally beneficial both for sound and reliability.
ECC82 tubes should have a life in the range of 10-20k hours (the G73-R allegedly was designed for 40000h lifespan target). Therefore tube life is a relatively low concern.
Being the AIC-10 a class A design, it injects some heat in the room and should consume something around 35-50W when not used, so a decent amount of energy is wasted by keeping it always on.
Furthermore, I have noticed that the AIC-10 takes only a few minutes to sound good, and about half an hour to reach its best sonic performances.
On the the other hand, I like the idea of limiting the number of power / thermal cycles of my gear, so with the AIC-10 I keep it on whenever I foresee to listen to it within the next day.
