apaar123
- Sep 10, 2016
How does it compare to senhesier ie80?
How does t20 vs vsonic gr07 bass
Thanks
what would you recommend after the t20. Would it be wise to get the gr07.How does t20 vs vsonic gr07 bass
Thanks
T20 much weighier in the bass,
The rha t20s Treble had a bit more emphasis, maybe slightly metallic
Thanks for the reply
the full size headphones I like are he500, thx00. I like bass, mids, wide Soundstage.what would you recommend after the t20. Would it be wise to get the gr07.
Depends on where you want to head. Give us some details, and I'm sure we can point you in the right direction. I'm pretty sure it's not GR07 though...
I hope u didnt think my post was negative towards the t20s!
Their really good, i was just describing their characteristics.
Their sweet!
Out of the box I'll agree with you in that the treble does sound harsh and on the metallic side - even with the bass filter installed. However for me after around 40 hours of use that subsided. Don't get me wrong, the treble remains quite prominent, but without that initial hard edge. Of course those with a sensitivity to treble may still find T20 on the fatiguing side even after burn in (some unkind people have suggested that the T in the T20 stands for Tinnitus)
I was never one to believe in burn in, at least in a significant way, but these have changed my mind.
Couldn't agree more edgy is the right word - when I put the T20 in my ears on the pre-launch party I had this WTH expression on my face - and plenty of others as well - then after a few hours burn in - that was replaced by a very pleasant smile that grew bigger and bigger.
Cheers!
Out of the box I'll agree with you in that the treble does sound harsh and on the metallic side - even with the bass filter installed. However for me after around 40 hours of use that subsided. Don't get me wrong, the treble remains quite prominent, but without that initial hard edge. Of course those with a sensitivity to treble may still find T20 on the fatiguing side even after burn in (some unkind people have suggested that the T in the T20 stands for Tinnitus )
Cheers!
Yeah, that was probably just you adjusting to the treble. I find the same thing happens to me every time I switch back to the T20 from a different IEM. Is that to say that they un-break in once I stop using them? No, simply that I was no longer mentally adjusted to them.
