juliojlo
- May 10, 2015
If I was in your shoes, se425. I listen to similar music you do. I did not like t10i.
hii. friend
buy used Shure SE535 $ 468.43 or buy new RHA T10i $ 385.35?
If se535 still has warranty, then go with that.
Hmm... I hope someone else can comment on this. I don't know.. I mean se535 is probably worth that price. The t10i is never going to be worth $385 in my opinion... I still wish you could look online for something.
I think if you are fine with sacrificing a little bit of quality (less bass response) when listening to bass heavy music (ex: rap/hip hop/dubstep/ some rock), you will enjoy the SE425's. They are a bit more well rounded and sound pretty good with just about any genre of music. It sounds like you listen to a variety of genres.
I don't know how else to describe it, but the RHA's sound a little bit "clubby" or "electronic" - this is not probably how you want to listen to jazz, blues, etc. The RHA's will probably sound a bit better when listening to rap/hip hop/ dubstep, but may be less than optimal for the others that were mentioned above.
The SE425's are most likely your best bet.
I was just typing the same thing.
I have the 425s as well and they have a particular sound to them. You need to demo them first.
Jazz and Blues - Silky smooth on the SE425s
Rock - Not as engaging due to the overall lack of speed
EDM/Hip Hop - Definitely not a good look on the SE425s.
Coming from someone who has owned the 215,315,425, and 535s I would like to think my descriptions are pretty accurate with this one.
Hello Friend
Could inform the shure SE535 CL used with $ 468.43?
or buy a new RHA t10i $ 385.35?
The Shure SE535 used would be better option than the T10?
very thanks.
Sorry I havent heard the T10 before.
Hello Friend,
If my doubt would,
The SE535 shure used for a month, it is worth buying $ 468.43?
has not guaranteed because it has not note, it is imported.
For me personally, $468 USD is not worth it for the 535s. That is IMO.
Hello Friend
very thanks.
