- Jan 17, 2003
Introduction
This year has already been monumental for me. It seems that my previous preference for hyper-detailed cans and analytical amps is on the wane. I recently had the opportunity to have an extended audition of the new Triad Audio Valvecode prototype amp for the past month and it has changed my mind about a couple of things. One is that although I like to hear lots of detail in my music, it should not be at the expense of musicality. Some of the hyper-detail I was enjoying, especially through a set of headphones like the Sony MDR-SA5000, kept me from being fully immersed in the music. I have also lost my fear of tubes and now have a better understanding of how tube amplification can make the music sound better. As is often the case with these demos, this has opened my eyes to new things and tempted me to upgrade or expand my equipment. So manufacturers, take note: demos are good for business. So keep ‘em coming guys!
Background
I have never been a “tube guy” when it comes to headphone amps. I was always concerned about heat, space, warm up time and understanding and dealing with tubes. It always seemed like more trouble than it was worth, especially since I have always gravitated more towards the cleaner, drier, analytical sound of solid state amps and like the idea of plug and play. Still, tubes held a sort of mystical allure for me. I do like the idea of tinkering with audio equipment even if I’m not the most knowledgeable guy out there when it comes to electronics.
When Triad Audio contacted my about sending the Valvecode to the NY meet on December 13, of course I couldn’t refuse, but deep down I wondered if I would even spend any time with it at home outside of the meet. Where would I put this thing? Would I burn my house down or worse yet, would I damage the amp and be responsible for destroying a one of a kind piece of headphone electronics, designed by one of the most respected audio designers around? Oh the shame, the shame.
The Valvecode and me at the NY Meet, December 13
However, I had no choice once the amp arrived a few days before the meet to make sure I could get it working. So I made some room in my listening area and set this beast up. And it truly is a beast, too. This thing must weigh 40 lbs. if it weighs an ounce. It accepts two input tubes, two output tubes and is tube rectified for a total of 5 tubes running the amp. The package included a variety of tubes, but more on that later.
Design Notes*
The Valvecode Prototype from Triad Audio
The Valvecode, according to its designer Philip P. LaRocco (ppl), is the world’s first all cascoded single ended triode amplifier. It utilizes triodes exclusively to avoid the nonlinearities of pentodes and remain true to the heritage of the single ended triode amplifier. It is implemented with cascode circuit design for low distortion and extended high frequency reproduction and to improve the performance and musicality of tube amplification.
The Valvecode employs an overbuilt power supply starting with a massive 240 watt power transformer rectified by a high current tube rectifier. It utilizes a fraction of its rated output for long life and low heat. The output transformer has a 100 watt core, laminated with high grade Z11 steel. It has a perfectly layered coil wound on a low loss nylon bobbin. The amp uses the Swiss made DACT CT2 stepped attenuator. It has only one Auricap coupling capacitor in the signal path. It is also fitted with a 6 position rotary impedance selector allowing the use of any headphone from 16 to 600 ohms and has two headphone jacks, one that utilizes the impedance selector, with the other one bypassing it.
The Valvecode is designed to operate with dual triode vacuum tubes with an 8 pin octal base such as tube types 6SN7 and 6BL7 or equivalent. For the output tubes the preferred tubes are the 6BL7GTA and the 6BL7GT and will also accept the 6BX7GTA and 6BX7GT types.
For input the recommended tube types are the 6SL7GT and 6SN7GT or GTA. The 6SL7 ahs more gain and the 6SN7 should provide greater dynamics. The 6BL7GTA also works and results in lower gain than either of the other two tubes but provides the highest dynamics.
The specified rectifier tube is the 5U4GB. The European GZ34 can be substituted with good results.
Initial Impressions
When the amp arrived I had four full size headphones on hand, Grado HF-1, Ultrasone Proline 750, Sony MDR-SA5000 and a pair of Denon AH-D5000 on loan from Lawton Audio with the “markl Mods” and rewired with Jena Labs cable. First up was the SA5000. This is technically my “best” headphone. It has the highest retail price of any of my cans and is recabled with a very well regarded Moon Audio Black Dragon cable (not including the Denos, which are not mine but are more expensive).
The SA5000 is well known as a very fast, clear and detailed headphone. As such, it is also considered to be somewhat fatiguing and can often sound bass shy. Plugging them into the Valvecode was a completely unexpected experience. They no longer sounded cold or analytical but extremely well balanced. Add this to the excellent speed, clarity, imaging and soundstage and the SA-5000 comes close to being my perfect headphone. And if the SA5000 isn’t my perfect headphone, the Valvecode certainly seems like the perfect amp for the cans.
The HF-1 were a nice surprise with the Valvecode. I am the original owner of these very limited edition headphones and I’ve held onto these more for their collectable value than for their sonic signature. Honestly, I have rarely listened to them and if you believe in burn in, they probably haven’t even been broken in yet. Plugging them into the Valvecode however was a completely different experience. The sound was very balanced, full and so much smoother than with any other amp I’ve tried them on. I have a set of Headphile C-pads for these and I thought that the Valvecode added the positive aspects of the C-pads without the negatives. With the C-pads the bass gets deeper and the sound is less fatiguing but it also sounds a bit mushy, losing the detail and excitement that makes the Grados so unique. With the Valvecode, bass was deep and tight, not at all flabby. Details were preserved but the “Grato” sound was completely eliminated. The soundstage was compressed, a signature of these headphones, but instrument separation was greatly improved.
Perhaps the only real disappointment I had with the Valvecode was with the Proline 750s. The Prolines have excellent soundstage capabilities. The Valvecode actually took them to a whole new level in that regard. The sound seemed to expand and encircle my head creating a fairly large stereo image. However, my disappointment came with the sound of the midrange. I’m not sure why but the sound was scooped out, as if the midrange had been cut. There just didn’t seem to be any synergy between the Valvecode and the Proline 750s.
Listening to the Denons took some time to get used to. At first, my impression was that there was too much bass. It was very deep but seemed to overpower the rest of the music. I’ve read some impressions of the Denons that state they need to be powered by solid state amplifiers to sound their best and I can agree to a certain extent, although with some tube rolling I was able to get them to sound very musical, while taming some of the bass. However, tipped the sound may have been towards the low end, the midrange on the Denons was breathtaking. I especially liked the sound of electric guitar, saxophone and vocals. On music that does not have electric bass the midrange is really allowed to bloom and sound so, well, musical.
Tube Rolling
Since the Valvecode accepts the 6SN7 there should be no limit to the amount of tube rolling that can be done. For many tube amp enthusiasts out there, this should be a tube roller’s dream.
Included with the amp were a few sets of alternate tubes: 2 6EM7; 2 RCA 6BL7GTA; 4 GE 6BL7GTA, 2 Black Plate, 2 Gray Plate; 2 Russian 6SN7GT; and the 5U4GB rectifier tube. When I first tried out the amp I got the recommended tube compliment wrong and used the 6BL7GTA in the input and the 6EM7. While this did not produce the most detail and the cleanest reproduction it actually made the SA5000 sound really nice. It was a bit slow and syrupy but I’ve come to the conclusion that this is just what the super fast and highly detailed SA5000 need to sound their best. I had never heard this headphone sound so good. However, plugging the Denons in with this tube combination sounded bloated. It was just too much bass to be enjoyable.
The clearest, airiest sound was realized by using the 6EM7 in the input, the RCA black plated 6BL7GTA in the output section. This gave the Denons new life and gave them a very musical feel with awesome soundstage. The sound of the electric guitar was some of the best I have ever heard outside of standing next to a well warmed up Mesa Boogie Road King. The Sonys also opened up more in this configuration but I could start to hear some of the sharpness to the highs that it sometimes displays. This was also the best tube configuration for the Grados. Where the Sonys still had some edginess to them, the Grados were detailed but smooth. The only drawback to the Grados however is that you really lost any semblance of soundstage as it sounded much more upfront. Not necessarily a bad thing but it did not allow the amp to show off what it does best for me: provide a lush yet detailed stereo image that expands well beyond your head.
I also tried the Russian 6SN7GT in the output stage and that was actually a good match for the Sonys. They lost some of their edge but still had the detail and space that makes them such a great headphone. They remained transparent without being hyper-detailed, which can sound unrealistic. However, the amp seemed to exhibit more hum with these tubes although it did not interfere with the enjoyment of the music.
Lasting Impressions
I’ll start with the negative side and I assume most of these issues have to do with the fact that this is a prototype and constructive criticism will be used to make the production model that much better. First, there was a low level hum that could be heard when no music was playing. This could be negated for the most part by switching the impedance selector and changing out the tubes. I found the 6EM7 in the input and black plated 6BL7GTA tubes in the output to be the quietest configuration. Bear in mind that all of my headphones are relatively low impedance (Grado – 32 ohms; Sony – 70 ohms; Ultrasone – 40 ohms; Denon – 25 ohms) so if I don’t know what it would sound like if you tried a pair of Sennheiser 650s or the like.
It also took a bit of trial and error to understand how to use the ohm selector switch and to understand the difference between the two headphone jacks. This was easily remedied by a few emails back and forth with Phil Larocco and I assume that when the amp goes into production there will be ample documentation.
This is a big piece of equipment. The thing weighs a ton and has a large footprint. This is necessary due to the high quality parts, but the amp is not for everyone. This is certainly not a desktop amp so start clearing out a space in your audio rack now.
Trying to make room for "The Beast".
On the positive side, this amp positively sings. There wasn’t a recording I threw at it that didn’t sound wonderful and even though I complain about the scooped out mids on the Prolines, there were times when I felt they sounded their best also. Dynamics on everything from classical to hard rock were outstanding.
There was a very definite openness to the presentation. On a headphone like the SA5000 the soundstage was absolutely huge, the best I’ve heard. Even on the Grados, which normally have a compressed soundstage, it was expanded to beyond my eyeballs, which is usually my experience with that headphone.
While treble detail and bass “oomph” was certainly there in spades, where the amp really shined was in the midrange. Guitars, vocals, alto sax, all sounded so tangible. This to me is the essence of a musical amp, since so much of the melody of music falls into the midrange.
The true indication of how much I enjoyed the amp was the emptiness I feel now that it’s gone. Music was such an effortless pleasure to listen to with it and my enjoyment of headphones has been reinvigorated.
Please do take what a say with a grain of salt. As I stated in the beginning, I am not a “tube guy”. This is my first extended audition of any tube amp, let alone one of this caliber. It is so hard to express intangible things like the enjoyment of music without resorting to some hyperbole. However, I do consider myself a life long music lover and as such think that in some way qualifies me to comment on this very fine piece of equipment. I do not know the exact details of when this amp will become generally available or what the price will be, but if you are an aficionado of tube amplification or just a music lover like me, you need to check out the Valvecode.
In a Nutshell
Pros
Cons
[size=xx-small]Endnotes
*Amp Design
The specifications on the build of the amp come from the designer, Philip P. Larocco. If something seems incorrect it is probably my fault. Although questions about the build of the amp would be greatly appreciated in this thread, your questions may be better answered by either Phil or Brad Taylor (remitrom on HeadFi). Ideally, they will answer any questions you have here so we have one place to discuss this amp. Over the past month these guys have shown themselves to be extremely knowledgeable, friendly and customer oriented, so I’m sure they would also welcome your private messages.
Source Equipment
Transport - SACDMod DVP-NS755V with stereo modifications
SACDmods.com--Upgrades for the Sony DVP-NS755V DVD/SACD Player
Ack dAck 2.0 with ultra resolution Teflon coupling capacitors
Ack! Industries
Music
While I listened to a variety of music with the Valvecode some the following is a selection of some of the albums that stood out when auditioning:
Chesky NARM Sampler 1991 – Various Artists
Of particular note are the tracks “My Blue Heaven” by John Pizzarelli and “Born in Chicago” by Natasha
Maria Rita – Maria Rita
Raising Sand – Robert Plant and Alison Krause
Tchaikovsy Violin Concerto in D major – Itzhak Perlman soloist
American Song – Andy Bey[/size]
Background
Design Notes*
Initial Impressions
Tube Rolling
Lasting Impressions
In a Nutshell
Pros
- New tube design by well respected audio engineer, Phil Larocco
- Great dynamics
- Involving Midrange
- Lush smoothness that does not sacrifice detail
- Deep and wide soundstage with excellent stereo imaging
- Many tube rolling options
Cons
- Low level background hum with some tube/headphone configurations
- Large size for the real estate challenged
- "Valvecode for Dummies" manual needed
*Amp Design
Source Equipment
Ack! Industries
Music
